Need HELP with removing rag joint!!!!
Old Sep 28, 2012 | 07:28 PM
AirborneSilva's Avatar
AirborneSilva
Default Need HELP with removing rag joint!!!!
How in the world do you get this stud off? there is no way I can see it come off, I tried to outline it in red, it's a thin line but there... Please help, if I don't get this done i can't put the motor in tomorrow.
Thanks!
Here's the end.
Old Sep 28, 2012 | 07:36 PM
oldalaskaman's Avatar
oldalaskaman
you're replacing both sides, just cut it
Old Sep 28, 2012 | 07:41 PM
edk136's Avatar
edk136
You may have to either loosen the gear box or the steering column to gain enough room to remove the rag joint. The last time I did one, I removed two of the three gear box mounting bolts to make room.
Old Sep 28, 2012 | 07:46 PM
AirborneSilva
So if I cut it how do i get the piece out thats in the steering box coupler (probably not what its callec I'm sure). Thanks for the help guys!
Old Sep 28, 2012 | 07:53 PM
oldalaskaman
thats a pretty good mess, you may , after you cut that, drop your steering column and move it back far enough to remove that. but it looks like you could get the rag side of that out of the way and it will tap off. I'd probably do the steering column though, less chance of an 'ooopppss'.
pb blaster would be good
btw , thats not 'in' the steering box, its just slid on the shaft like the steering side
since you have the motor out, tap the steering end down after you cut that, piece it out if you need to, tap the steering box side up, piece it also if needed, install the new one, donr, a dremel or grinder works also.
Old Sep 28, 2012 | 07:59 PM
AirborneSilva
Not sure what you're referring to when you say tap off. Are you talkin the stud or coupler.
Old Sep 28, 2012 | 08:03 PM
oldalaskaman
the piece thats on your steering column is a slip on , tap it down towards the steering box. the piece thats on the steering box shaft is also a slip on. when the upper piece is out of the way, tap it up towards the firewall, gently
cut that stud, its rusted together, you wont need any of that.
the piece thats on your steering box shaft has a split where the pinch bolt was, drive a good sized screwdriver in the split and that will loosen the lower half making it easier to slide upwards.
Old Sep 28, 2012 | 08:06 PM
AirborneSilva
Ok but then what do i do with that stud that's holding the rag joint on?
Old Sep 28, 2012 | 08:07 PM
oldalaskaman
Cut the stud, both of them, if you had the new rag joint this would make more sense
Old Sep 28, 2012 | 08:17 PM
AirborneSilva
I do have the new one, i wwnt to be sure im not screwing anything up by cutting something and then finding out that was not correct then im screwed.... so, if i cut the stude can i then get whats left out of the coupler? Not trying to be difficult, just want to not put mysef in a worse spot.
Old Sep 28, 2012 | 08:19 PM
oldalaskaman
look at your new rag joint, all those rusted pieces on the old one arent needed, and yes
Old Sep 28, 2012 | 08:25 PM
AirborneSilva
I got that but how do i get the stud out of the piece thats on the coupler connected to the steering box. If i cut the stud there is a portion that will be in coupler. I dont know how to ask better... sorry.
Old Sep 28, 2012 | 08:27 PM
oldalaskaman
put a line mark on both shafts , steering column and steering box, and try not to rotate either one, when you put the new rag joint on, make sure the two marks are lined up with each other, that way you wont have to play with trying to get your steering wheel back right.
Old Sep 28, 2012 | 08:28 PM
oldalaskaman
does your new rag join have those studs, and two bolts to hold it together,? you dont need the old pieces. you wont need anything you remove from that.
Old Sep 28, 2012 | 08:35 PM
AirborneSilva
Yes it does have new bolts, my problem is if i cut the stud (in first pic), will I be able to get the pieces out of the part on the steering box to put it back together with the pieces that came with the kit. the instructions don't say anything about how to do that or if i have to. Are they just pressed in? how does it come out???
I know you are helping and are being very patient, I do appreciate you help!
Old Sep 28, 2012 | 08:37 PM
oldalaskaman
you don want any part of that , take the bolts out of your new joint , you'll see new studs
Old Sep 28, 2012 | 08:42 PM
oldalaskaman
http://www.google.com/url?sa=t&rct=j...J4UPQZB3_x67fA
check out this thread, really good pictures
To Need HELP with removing rag joint!!!!
Old Sep 28, 2012 | 08:44 PM
AirborneSilva
Sorry, i guess im a moron, i dont get it! If i dont take that stud uff, cuttint it or otherwise, the i cant take the old rag joint off, or whats left of it.
Old Sep 28, 2012 | 08:48 PM
AirborneSilva
Thank you for link, pictures may explain what you're trying to tell me.
Old Sep 28, 2012 | 08:52 PM
oldalaskaman
http://api.viglink.com/api/click?for...13488798707022
more good info
http://forums.corvetteforum.com/c3-t...+joint+removal
