Torque control arms...am I missing something?
The bolts that go thru the frame / bushings/ frame to hold the arms in will NOT BUDGE.
I finally got them to turn after using a torch to heat it up and a 3 ft breaker bar...however, now i can get them to spin a little - but these buggers sill not come out. I have raised the arms with a jack to try and relieve pressure - swayed the arms side to side....nothing.
I tried a bigger BFH and I dont want to screw anything up.
Am I missing something? This shouldn't be that hard.... OR should I resort to the sawsall and cut the bolts inside the frame to remove?
http://forums.corvetteforum.com/c3-t...-arm-hell.html
Oh...and good luck.
