Another satisfied DeWitts customer!!
The electric fans had a dramatic effect at slow speeds but at highway speeds it still got hotter than I wanted, as high as 220 to 225 on hot days with A/C on.
The extension of the spoiler lowered the temp about 20* on average on 90ish days. So instead of 240 I would see maybe 220.
Still I wanted more. If I am going to increase the HP of this engine then I am also going to increase the heat it produces.
I looked at and considered many different aluminum radiators but in the end decided that doing it once and having a good fit were priorities in this case.
So I bought this radiator;
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Just got it installed yesterday. The fit was perfect. I don't mean it was close, it was perfect! Amazing to me that this is a product that lives up to it's hype. Bravo Mr. Dewitt! I even have a oil cooler between my A/C condenser and the radiator and this new radiator did not interfere with that at all. The new rad also came with the appropriate replacement rubber mounts top and bottom.
The cooling of this new rad is nothing short of astonishing.
My temp gauge starts at 100* for the first mark and 200* for the mark straight up on the gauge. In between is a mark half way. So I guess that would represent 150*. The entire time I drove the car at 75 to 80 MPH the gauge did not budge from what appeared to be 175*. Which is about right since I have a 180* thermostat installed. Nothing I did in the past ever saw a running temp this cool. On the radiator I have a radiator cap with a temp gauge in it and when the inside gauge read 175* the gauge on the radiator read 130*. Previously the radiator cap would read 180*-200* with the interior gauge reading of 200* to 220*.
So Thank you very much Zips and Dewitts for a quality product.
http://www.ebay.com/itm/Camaro-Trans...5d9d53&vxp=mtr
If you look around you may be able to get it cheaper or at least free shipping. It is accurate. I verified it many times with an IR temp gun.
If only every manufacturer took their same approach to customer service!!
I am a VERY happy customer of theirs, they are top notch in my book!
