Rochester FI on C3 ?
on a C3? I would think if they worked ok with a 327, they should work the same on a 350. Perhaps the throttle body might have to be a little larger for the extra displacement. I had the FI unit on my 64 couple and was happy with it. It would get better mileage then the carburated cars...if you kept your foot out of it. Oh course now, the
Rochester units are considered "collector items" and the prices are out of sight.
Jeff
The Rochester FI is really used to massively increase the value of a car that was originally equipped with it.
It likely has better fuel atomization than a carburetor, but far more specific tuning requirements.
A TPIS MiniRam, GM RamJet, or Holley Stealth Ram will all achieve a decently respectable fuelly "look", and work significantly better.
http://www.vetteweb.com/tech/vemp_07...te_efi_system/
Yes, i wanted to say the LT1 conversion is a close match but with electrionic FI.
I believe u can convert the LT1 intake to GEN I by drilling out the distributor hole - but i can't recall how they make the thermostat crossover. Maybe they (GEN 3 camaros or C4 vette owners) use a different manifold base. But I have read its been done and maybe a forum search would find one.Good luck and post what u can find,
cardo0
Jeff
Simple installation,,,you must set up for using a cable connection,,,65's use a rod,,,for the accelerator,,,,simple custom mounting bracket is required for the cable. You must use either an LT-1 or big block hood for clearance,,,and you must devise an air cleaner.
***** out performance will be down a bit as Rochester is only 625 CFM or so, whereas with a 700 Holley double pumper or 780 vacuum carb, engine had more air and fuel to work with.
But, that doesn't change how cool the Rochester unit would look on a C3. I've thought about it myself....then I woke up and realized the $$$ involved.
And Edlebrock. Just all those manifolds have the throttle body and air cleaner stuck on the end which takes from the vintage look.
I think all are an improvement over the carb or vintage FI but the C3 just looks better with the air scoop sticking upwards rather than forwards. Yeah that cheetah is bad azz looking.
cardo0
I am not certain if I am remembering correctly, but think that I've seen a Rochester unit with 2 air meters on the left side of the dog house. Likely someone will correct me if I'm remembering wrongly.
Love the looks, since my '62 was a factory fuelie, I was rather hooked.
