Oil Pressure???
Old Oct 5, 2012 | 12:55 PM
Stoli & Tonic's Avatar
Stoli & Tonic
Default Oil Pressure???
When I start the car in the morning I have a good 40 lb of oil pressure. Get on the freeway to work for about 30 minutes with no problems. But as soon as i get off the freeway and stop at a light, the oil pressure drops to zero. I check the dip stick and it shows that its full. Im stumped. Any ideas??
Old Oct 5, 2012 | 01:17 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Need an oil change.
Old Oct 5, 2012 | 02:06 PM
71 f/w driver's Avatar
71 f/w driver
have you had a recent oil change? what weight oil are you using? any unusual noises... like knocks or pings? When I bought my 71 previous owner had the oil changed. after 1 year (600 miles) I changed the oil to 10w30 and developed the same symptons as your, changed oil again to 20w50..I now have 35 psi at idle and 40 psi when driving. My car has 158000 miles.
There was some engine work done but none of the previous owners when or what was done. Im 4th owner.
Mike
Old Oct 5, 2012 | 02:15 PM
Stoli & Tonic
I am using 10 w30. I've only put about 200 miles since the last oil change. I'll try the 50 weight. Thanks.
Old Oct 5, 2012 | 02:19 PM
brando1118's Avatar
brando1118
Check for proper sending unit and gauge functionality.
Old Oct 5, 2012 | 02:30 PM
Belgian1979vette's Avatar
Belgian1979vette
The drop in pressure is from the oil warming up.
Excessive oil pressure drop can come from only a couple of things : to wide bearing clearances or things like oiled lifter, spring oilers or a pump with too much clearance
Do you know any spec from your engine ?
If it didn't have this problem before could be the pump.
Old Oct 5, 2012 | 05:40 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Oil pressure at normal operation temp is usually 10lb per 1000 rpm depending on the hot oil viscosity....in drive at idle you should be at less than 1k rpm so your oil gauge will show less than 10lbs....the way it's graded it looks like no pressure.
I do think you should be seeing more than 40lbs when cold (depending on your rpm)...more toward the 60/70 lb range......once at normal operating pressure 35/40 lbs at cruising speed is normal.
BTW, I've used 10w30 all my life without any engine related problems.
Old Nov 23, 2012 | 05:18 PM
Stoli & Tonic
Oil change to a heavier weight high mileage oil did the trick.
Old Nov 23, 2012 | 05:29 PM
7T1vette's Avatar
7T1vette
Clheck oil pressure with another gauge. Plumb in at the pipe plug near the oil filter. Chances are that your gauge just reads a little low at low pressure and that you just haven't noticed it before. If it didn't have any oil pressure at idle, you would notice the lifters clacking in about 10 seconds. Since you don't hear the lifters at idle (do you?), your 'problem' is just the inaccuracy of the stock gauge.
Old Nov 23, 2012 | 08:11 PM
bpassmore's Avatar
bpassmore
check with a mechanical gauge.
My oil pressure went to the max side, replaced the sender wit a BW unit, oil went to 0 at idle hot......bad sender........another new one worked great, 20W40 idles @about 30 runs about 45-50. just like it was before the failure.
To Oil Pressure???
