The problems - What to do first.
Old Oct 6, 2012 | 09:19 AM
dbartol1's Avatar
dbartol1
Default The problems - What to do first.
So I picked up this car a few weeks back off Ebay (yes Ebay). (1979 with a 350 bored out to .060 etc.)
After getting it home and going over it I have the following list of problems. I want to do as much of the work myself, but I am at best average on car mechanics. I am however very good at working with tools and am a quick learner. Here's the list:
Electrical:
-Instrument cluster lights don't work (except the brake warning light, which wont turn off).
-Dash center console lights don't work (except "GEN" light).
-Cruise doesn't work
-Cig. Lighter doesn't work
-Reverse Lights don't work (needed to pass inspection in NY)
-Power Locks don't work
-Clock not working
Mechanically:
-E Brake (I assume it will seize, hence the brake light stuck on, but am afraid to try it)
-Steering - seems loose. The car drifts in the lanes and feels unsafe at anything above 65). Seems to have a lot of play.
-Suspension (not sure, because of the steering issue. Maybe a combination of the two. It is very stiff, but this might be normal?).
-Pitman arm seems to have a bit of play in it.
-Wiper fluid doesn't pump.
-Missing hood blanket.
-Slight smell of urine (not kidding). While replacing the instrument cluster bulbs (to no avail) I discovered a nice helping of mouse sh%t inside the dash. I have cleaned it up pretty well but last I knew mice don't have restrooms, so I imaging the f%@ers pissed everywhere.
So what's my best course of action? The E brake and reverse lights are needed to pass NYS inspections. The steering is high on the list for safety, but I fear I can't diagnose the problem correctly and buy unneeded parts or poor quality parts. Same with suspension. That and the fact that I am uncertain about what parts get lubricated.
Thanks all!
Old Oct 6, 2012 | 09:54 AM
ezobens's Avatar
ezobens
OK- Here is my stab at it..
With the mouse infestation, my guess is that they chewed through your ground connections, the circuit board or both. That is why nothing has power to the dash/console.
The brake light can indicate either the parking brake is on (or the switch is bad in the console) or you have a braking system issue (hydraulic imbalance). The same brake light is used for both systems.
If the parking brake handle is all the way down, check the switch to make sure it's not still making a connection with the handle down-
If that's not the cause, than you may have other braking issues (or the wiring is grounding itself somewhere due to mouse damage).
Reverse light is also probably critter related (it is an automatic or 4-speed?).
Loose steering is pretty common on Vettes that haven't been well maintained.
Sounds like you need to have you steering box rebuilt and most likely the rest of the power steering system as well as the suspension components (bushings, ball joints, tie rods etc).
Welcome to the wonderful and expensive world of Vette ownership!
Old Oct 6, 2012 | 10:23 AM
Tim H's Avatar
Tim H
Electrical:
-Clock not working
Mechanically:
Thanks all!
There is no helping the whole project will follow the path of the first step of buying someone elses problems off Ebay.
Otherwise just start with step 1 that will get to driving it the fastest.
Old Oct 6, 2012 | 10:40 AM
billcarson's Avatar
billcarson
the pitman arm itself does not have play.it is tapered at one end and splined at the other. if the steering control connection to the ball stud came loose the stud may be worn causing play.at the steering box connection there is a bearing on it's vertical shaft that may be worn.good luck.
Old Oct 6, 2012 | 10:48 AM
KenSny's Avatar
KenSny
This is a good example of "never buy a car unseen", or at least having it eyeballed by someone you trust.
Lots of luck and patience. And I mean LOTS, because you are going to need it to sort out that mess.
Old Oct 6, 2012 | 12:34 PM
dbartol1's Avatar
dbartol1
The play is at the tapered end. Do you think the arm needs replacing or the bolt that goes through the arm, or both?
Old Oct 6, 2012 | 12:51 PM
dbartol1's Avatar
dbartol1
Thanks for the reply. Its a 4 speed. The brake light is part of the cluster so I think it is getting atleast partial power. The brakes seem to be fine, I think it is the emergency brake thats causing the light.
Old Oct 6, 2012 | 01:43 PM
billcarson's Avatar
billcarson
it may be loose on the ball-stud requiring the ball studs replacement,available,or the play could be the natural play when the engine is off.there will be much less play with the engine running and the ps system pressurized.mine was loose and worn and i rebuilt both sides of the power steering control valve.(used to require 2 kits)
Old Oct 6, 2012 | 02:19 PM
ezobens's Avatar
ezobens
Not sure about 79' but the earlier models had the reverse switch on the transmission linkage under the car-
Often hacks that don't pay attention or don't care will either remove the reverse switch or just blow off re-connecting the link that connects the switch to the reverse lever.
I still think you are missing a ground on your cluster-
The Gen and Brake lights have dedicated grounds and is probably why they are still working.
The fact that nothing else lights up or works would make me suspect a general ground issue to the cluster.
Old Oct 6, 2012 | 03:18 PM
SIXFOOTER's Avatar
SIXFOOTER
Here is my approach. Safety items first. Brakes, its better to have it stop well before anything else. Disconnect the brake light switch on the proportioning valve to see if that turns off the light, if so, fill and bleed brakes and reset the valve. If not, then investigate the switch on the p-brake handle, all it does is tell you the brake handle is not all the way down.
Steering is #2, check out the rag joint where the steering shaft goes into the steering box, when I got my 1st one it was almost completely gone. Then the other steering components that wear: tie rod ends, ball joints, idler are. Then steering control valve. A good alignment will go a long way to making it handle better once the other stuff is fixed.
Brake lights and reverse lights would be next, you will need a good schematik and a test light, maybe some help learning to use them from in here.
Then the dash lights, everyone immediately starts taking about ground wires, sometimes thats the problem, sometimes not. Walk through the schematic one step at a time, Fuses, Switches, connections etc...
SIXFOOTER's Avatar
SIXFOOTER
Oh, post up some pics, welcome to the forum,
Old Oct 6, 2012 | 05:15 PM
dbartol1's Avatar
dbartol1
Thank you. I'll get some pics soon. I pulled that valve prop. switch and the light went out. Now a question, why would i fill the reservoir just to bleed it? When you say reset the switch, do you mean to just plug it back in? Is your thought that there is air in the brake line? Is that why I should bleed the brakes?
Also, do you know what fuse controls reverse lights and isn't the instrument cluster fuse the same fuse as the brake light fuse? Thanks again.
Old Oct 7, 2012 | 12:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Dash lights (all of them) use the IP fuse. Replace the fuse. All of them dim up and down with the headlight switch ****. If you have no up or down, the rheostat on the headlight switch has died.
Ebrake light usually indicates a problem with the brake system if the ebrake handle is not on.
Have you ordered the assembly instruction manual (AIM)? It will help.
Get it safely drivable; pass inspection. Then you can determine what else you might need to do.
Old Oct 7, 2012 | 03:53 PM
dbartol1's Avatar
dbartol1
Thanks Mike,
No I dont have that manual. Now for my dumb question of the day. Which fuse is the IP fuse? I thought it was the top towards the left(7.5 amp). Am i wrong?
To The problems - What to do first.
