1968 Horn Button Restoration
Old Oct 6, 2012 | 01:57 PM
DESI6327's Avatar
DESI6327
Default 1968 Horn Button Restoration
Looking to restore my '68 horn button. It's in very good shape. Just needs to be freshened up. I've also noticed some spotting....(May be some cleaner someone sprayed on and got inside) on the inside. It's black in color and I'm guessing a flat black would be the choice
Anyone have any experience in taking one of these apart?
Thanks in advance
Bob
Old Oct 6, 2012 | 02:42 PM
69ttop's Avatar
69ttop
I masked the center emblem with tape the sand blasted the outer ring prime and paint.
I didnt want to take it apart.
Old Oct 7, 2012 | 12:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you looked at your horn button? The attaching studs on the back side are spun closed. You'll have to decide whether you want to open it up.
Old Oct 23, 2012 | 11:20 AM
DESI6327's Avatar
DESI6327
Been a while..didn't know you'd responded...
How does one go about taking the horn button apart. I see that it's spun closed...What's the trick?
Thanks,
Bob
Old Oct 23, 2012 | 03:10 PM
Alan 71's Avatar
Alan 71
Hi Bob,
I believe the paint on the horn ring and the rest of the column is semi-flat, not flat.
Regards,
Alan
Old Oct 23, 2012 | 03:16 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by DESI6327
...How does one go about taking the horn button apart...
This one didn't. I left well enough alone.
...I see that it's spun closed...What's the trick?...
I've read a couple of accounts where the spins were ground off. The problem is not getting it apart; the problem is keeping it together after the spins are gone.
Good luck.
To 1968 Horn Button Restoration
