C-3 header help
Old Oct 7, 2012 | 10:51 AM
Msp1953's Avatar
Msp1953
6th Gear
Default C-3 header help
PUT ON NEW HEADERS ON MY 76 350. I NOW HAVE 2 ISSUES.
1. I HAVE ONLY 3" OF GROUND CLEARANCE. HEADERS ARE 18" FROM TOP TO BOTTOM OF COLLECTORS. SCRAPPING JUST ABOUT EVERYTHING IS GETTING OLD.
2. MY A/C BRACKETS AND COMPRESSOR NOT LONGER LINE UP.
IS THERE A WAY TO FIND A HEADER THAT IS SHORTER?
DOES ANYONE KNOW OF A DIFFERENT BRACKETS AND COMPRESSOR TO INSTALL SO I CAN MAKE MY WIFE HAPPY?
I KNOW GOOD LUCK ON THE SECOND.
ANY HELP OR INFORMATION WOULD BE GREATLY APPRECIATED
Old Oct 7, 2012 | 12:29 PM
BKbroiler's Avatar
BKbroiler
Regarding the ground clearance - Check the condition of your transmission mount. If it is original, it gets compressed and lowers the back of the trans which tilts the engine back and lowers the collectors.
Old Oct 7, 2012 | 05:41 PM
hugie82's Avatar
hugie82
You can use block Hugger headers and use washers to shim out the A/C brackets.
Old Apr 11, 2013 | 07:57 PM
Msp1953's Avatar
Msp1953
6th Gear
Kinda HELP!!!!!!!!!!!!!!!!While redoing my interior, I have found 5 flasher units.....Yes I said 5...Can anyone give me an ideas what they are ALL for? I am putting LEDs in my turn signals and can not get them to flash. I have 1 LED flasher, should I change them all to LED
Thank You
Old Apr 12, 2013 | 08:04 AM
woodvette03's Avatar
woodvette03
i agree with hugie82.
i used shorty steet rod / block hugger headers with spacers and washers for the AC and have no issues on my '76.
Old Apr 12, 2013 | 08:11 AM
540 vette's Avatar
540 vette
Thank You
Start another thread you will get more answers.
Old Apr 12, 2013 | 08:19 PM
jb78L-82's Avatar
jb78L-82
McJacks
Old Apr 16, 2013 | 01:16 PM
Ralphbf's Avatar
Ralphbf
I purchased the Summit headers.
Good fit, no issues and they had a instruction sheet from Hooker Headers in the box. They were about $120.00 if I remember right.
Old Apr 16, 2013 | 09:08 PM
Iggycat2009's Avatar
Iggycat2009
Installed long tube headers on my 76 and they fit fine.. Clearance will always be an issue so take it slow over speed bumps..
In reference to your wife and the AC problem.. I don't know what to tell you there.. ..but good luck..
Mike
To C-3 header help
