egr.........
Old Oct 7, 2012 | 12:16 PM
ramair_bryan's Avatar
ramair_bryan
Default egr.........
If the heads had no exhaust cross over ports..........But the manifold still has the EGR.............would the EGR still pass the smog test in california if no one knew?...............
Old Oct 7, 2012 | 01:08 PM
7t9l82's Avatar
7t9l82
more than likely it would pass the visual inspection.
Old Oct 7, 2012 | 08:10 PM
ramair_bryan
Cool.............is there any smog guys out there that would squeeze one as a test?.........or what would they do for testing. Wondering if I'm going to have to drill a hole in the ex port to make this head pass..........
Old Oct 7, 2012 | 09:53 PM
ramair_bryan
Good news................compressing the diaphragm still causes a vacuum leak, so it stumbles the engine as in testing. So.........maybe only if the tail pipe test showed too many nox numbers, they would look at the EGR......................
Old Oct 10, 2012 | 12:56 AM
RIJVETTES's Avatar
RIJVETTES
The EGR lowers NOX. Yours has to be functional, with or without yer heads, or you'll fail the tail pipe test.
You may want to pay for a "sample" test, before your data gets sent to Sacramento DMV
To egr.........
