clunking noise
Old Oct 7, 2012 | 03:08 PM
jeremy383's Avatar
jeremy383
Navigator
Default clunking noise
I have a clunking noise in the left rear of my 76 vette at like idle speeds sometimes,not all the time. Could it be the U joints on the axle?
Old Oct 7, 2012 | 04:32 PM
YANKEECORVETTE's Avatar
YANKEECORVETTE
Could be the u joints, the e brake could be dragging the shoes on the inner brake drum, also your rear end maybe low on lube or tired. Your are going to have to jack the car up w/ both wheels off the ground. Spinning the wheels by hand out of gear, should help to duplicate your noise. The e brake cable maybe too loose or the shoes may need adjusting. Check the lube level to eliminate that possiblity. I personal had the same issue and these tasks helped me out.
Old Dec 18, 2012 | 08:38 AM
coreyt's Avatar
coreyt
thanks for the tips, i thought these vettes all had rear disk breaks.
I have the same issue as of yesterday. from a stop or when im just about to come to a stop i get a clunking noise. every one or two seconds in frequency until i hit maybe 10 mph. then it goes away. I just bled the brakes and i'm wondering if maybe the the brakes are sticking or if there is something more serious going on. ill try your suggestions and see what i see.
Old Dec 18, 2012 | 09:13 AM
BHRIG's Avatar
BHRIG
sounds as if clutches in rear need attention.
when was the last time fluid in rear was changed?
was GM posi-fluid added to rear upon refiling?
If you make SLOW figure 8's ,do you have the clicking in rear?
If you do, try changing the fluid in rear..pump out old, replace with 1
bottle of GM posi-fluid first then top off to bottom of fill plug with
gear oil.
Old Dec 18, 2012 | 10:31 AM
coreyt's Avatar
coreyt
gear oil.
thanks for the advice, I have only had the car about a month so im not sure the last time the fluid was changed. I will start here and see what happens. thanks,
Corey
To clunking noise
