Body Removal Question
Old Dec 1, 2012 | 01:14 PM
mac79vette's Avatar
mac79vette
Default Body Removal Question
On a 1979 Corvette can I remove the entire body as a single unit from the frame? So complete body, bumpers, hood, interior, and glass all in one unit.
Rebuilding suspension, have to also replace the body mounts along with all the brake lines and fuel lines. I figured while I am at it strip and paint the frame.
Old Dec 1, 2012 | 03:32 PM
gcusmano74's Avatar
gcusmano74
The bumper covers have to come off, front and rear. Disconnect and remove the battery. Then disconnect everthing else.
Including but not limited to: at least four grounding wires, steering column "rag" joint, all electrical connections between frame, engine and body, all radiator and heater hoses, engine fan, seat belt reinforcements, parking brake cable, clutch linkage and shift boot (on a manual), and linkage on an automatic, master cylinder brake lines (I disconnected the MC from the firewall and supported it on the frame with a Rube Goldberg device of wood and duct tape, so I would not disturb the hydraulics) fuel tank sender wiring, and the vacuum hoses that operate the headlight mechanism. I unbolted the AC compressor from the engine and fastened it to the fender with some old wire, so I would not crack the seals. The hardest part is, that the eight body mount bolts are often quite rusted. Don't forget the radiator mount to frame bolts. Noland Adams used to sell a video about it.
Good luck to you. It's a bunch of work. But very satisfying when you are all done.
Old Dec 1, 2012 | 09:39 PM
mac79vette's Avatar
mac79vette
Thank you for the info.
What is the best way to lift the body? It is complete and painted so I do not want to cause any damage.
The last car I did this with was a 1956 Bel Air, I had just used a engine hoist and a strap.
Also with the Bel Air I had built two large saw horses from wood and had set the body on that. They went from one side to the other and it worked really. It allowed me to store the frame under it. Is there adequate support on the corvette body to do the same?
Old Dec 2, 2012 | 07:07 AM
69ttop's Avatar
69ttop
I used a 2 ton eng. hoist, eng. balancer and straps. I did a test lift about 6 inch. and found that the weight of the body pushed the doors in so I ran the rear straps inside the opened doors and ran the front straps as far forward as I could with the straps placed forward of the door seam. I placed the hoist just forward of the windshield frame. I removed as much weight as I could and placed the body on a dolly that I built from plans that was recommended in a corvette forum. I put towels under the forward straps to protect the paint.
Old Dec 2, 2012 | 11:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mac79vette
...On a 1979 Corvette can I remove the entire body as a single unit from the frame?...
Yes.
Old Dec 2, 2012 | 08:44 PM
mac79vette's Avatar
mac79vette
Can I use just standard straps to lift the body, or should I use the ones that are made to lift a C3? It seams to me that I could just use tow straps and wrap them around the body.
Old Dec 3, 2012 | 08:26 AM
gcusmano74's Avatar
gcusmano74
Of course you could. It's just easier to use the straps that are already cut to the right length.
The Center of Gravity on the separated body of a C3 is about right above the shift lever. So get your hoist point straight above that, and hook the straps just forward and rearward of the doors on both sides. I added two ropes to the top of radiator support.
Go slow. There's always a wire or something that might hang up as you lift.
Old Dec 4, 2012 | 01:24 AM
mac79vette's Avatar
mac79vette
Is the center of gravity above the shifter with the front clip still attached? I ordered the straps from Corvette Central for $69.99.
Old Dec 4, 2012 | 12:57 PM
gcusmano74's Avatar
gcusmano74
CG is above the shifter when the body is complete. If you remove the front clip, the CG will be more to the rear of the car.
Before you drop the body back, when you are all done, find a couple of pieces of 1/4" steel pipe. You can use them as alignment pins, to place the body back correctly on the frame. If you open the doors, and remove the sill plates, you will find two plastic plugs, front and rear. Under one of each of the holes per side, you will find a hole in the frame. Use your 1/4" pipes to guide the body back on the frame. If you can't find 1/4" pipe, try to find 9/16" rods.
Good luck.
Old Dec 13, 2012 | 02:54 PM
mac79vette's Avatar
mac79vette
The straps just arrived in the mail. The mettle hooks are hitting the body, is this correct? It looks like they would crush the fiberglass. Any thoughts?
Old Dec 13, 2012 | 07:43 PM
gcusmano74's Avatar
gcusmano74
The straps hook onto the steel rocker arm rails, under the fiberglass, outboard of the frame. Remove the trim pieces under each door and you can access them easily. I had to open up the hooks on the lift kit a bit so they would fit correctly. I used a piece of solid round bar and a press. You could do it with a vise, if necessary.
Old Dec 14, 2012 | 02:06 PM
69ttop's Avatar
69ttop
think he means rocker panels just below the door sills which is a part of the bird cage
Old Dec 14, 2012 | 10:21 PM
mac79vette's Avatar
mac79vette
When I hook the hooks on the straps into the mettle channels under the door sills with the trim pieces removed the top of the mettle hook contacts the body, so that if lifted the load would be against the body.
Thank you for the idea of using mettle bar and a vice to open the hooks up, I believe that this should do the trick. I will try it on my day off....Sunday and post how it fits.
Old Dec 16, 2012 | 07:44 PM
mac79vette's Avatar
mac79vette
I really need some help with what I need to disconnect on the front of the body to remove the body from the frame. There is the cylinder shaped cross member piece that bolts on the very front of the frame on both sides, plus on the out side of that the bumper brackets. This is attached to the end of the frame on each side with four large bolts, do I need to remove these four bolts to detach the front of the body?
Reading other post I was thinking that the large bolts that connect the radiator core support to the frame(cylinder shaped cross member piece) was all that was needed on the front, but after looking at everything I realize that there is a lot more to it.
Everything else is now apart, just have to figure the front out and the body will be ready to pull from the frame.
Is there a easy way to post photos on here?
Old Dec 16, 2012 | 09:46 PM
gcusmano74's Avatar
gcusmano74
On my '74, the inner bumper supports stayed on the body. I just removed the bumper cover.
As for photos, you need to use "photobucket". Somehow. Don't ask me how. I dunno.
Old Dec 16, 2012 | 11:29 PM
mac79vette's Avatar
mac79vette
I have seen photos where the body has been removed with the rubber bumper covers still on, just trying to figure out how to do it with out braking something.
Old Dec 17, 2012 | 07:45 AM
MIKE80's Avatar
MIKE80
Create a Photobucket account, upload your photos, copy the IMG code (click on it and it will copy), and then paste it into your forum post.
To Body Removal Question
Old Dec 17, 2012 | 08:21 AM
GT's 78's Avatar
GT's 78
I guess you already have a body cart if your ready to lift. I just got done with mine and getting ready to disassemble it. I'm in N.C.
Old Dec 17, 2012 | 10:16 AM
Easy Mike's Avatar
Easy Mike
...I have seen photos where the body has been removed with the rubber bumper covers still on, just trying to figure out how to do it with out braking something...
All of the crash bumper hardware behind the bumper cover would have to be disconnected before you could lift the body with the cover in place. Note my pic of 81 body drop at St. Louis above. The factory did not install the front bumper cover until after body drop.
Old Dec 17, 2012 | 10:15 PM
mac79vette's Avatar
mac79vette
Yes just built one
