Ignition problem, need help....
Old Oct 8, 2012 | 09:11 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Default Ignition problem, need help....
Hey folks, had an unfortunate occurance on Saturday. Out for a cruise on a beautiful day with the top down, when it suddenly felt like I lost spark. Lasted maybe a second or two, but came back with a loud backfire (which confirmed in my mind I had lost spark). This happened three times on the ride before I got back to the house.
Now normally, the first thing I would do is shoot a new set of points and a new condenser in there. But, I have one of these in my dizzy, installed by a previous owner:
I have no idea how that works, so I am not sure where to start looking for the problem.
Any suggestions?
Old Oct 8, 2012 | 10:08 AM
oldalaskaman's Avatar
oldalaskaman
check for a loose connection/or ground, those are pretty reliable
Old Oct 8, 2012 | 04:36 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Yeah,..check all the wiring to and from the coil and distributor
Old Oct 8, 2012 | 04:40 PM
MelWff's Avatar
MelWff
Red wire is power
Green wire is signal to coil negative
Brown wire is ground
Have mine for a couple of decades. When placing rotor back do not overtighten the nuts. If you have a dwell meter hook it up and see if you get a reading while cranking the engine with cap off.
Old Oct 9, 2012 | 09:24 AM
Derrick Reynolds
Thanks guys, I'll check all the wires this weekend. I actually took that picture some years ago, it just came in handy yesterday when I posted. Looking at the picture again, it looks like there is still a condenser there bracketed to the coil. Does that do anything when using the Mallory? Should I replace that? I have never replaced it in the 4+ years I have owned the car. I have only driven it a little over 5000 miles since I have owned it, but I have no idea how long it has been in there before I bought it.
Old Oct 9, 2012 | 09:53 AM
oldalaskaman
set up like that , the condenser is usually for ignition noise supression for your radio
Old Oct 9, 2012 | 09:55 AM
SuperBuickGuy's Avatar
SuperBuickGuy
clean and adjust the points.
or better yet, replace all of the inner workings with a Pertronix ignition
otherwise, your distributor looks in good shape (weights)
Old Oct 9, 2012 | 09:58 AM
oldalaskaman
that red thing , takes the place of the points, same as pertronix, its an electronic ignition conversion, eliminates points, hope this helps
Old Oct 9, 2012 | 11:21 AM
SuperBuickGuy
d'oh!!!
Old Oct 9, 2012 | 11:24 AM
oldalaskaman
its ok, I do that ...daily, sometimes hourly
Old Oct 9, 2012 | 02:15 PM
Derrick Reynolds
OK, then, low priority. I run with the full ignition shielding in place too, even though I never turn on the radio.
Old Oct 9, 2012 | 04:41 PM
SuperBuickGuy
radio? that's what dual exhaust is all about
Old Oct 9, 2012 | 05:14 PM
7T1vette's Avatar
7T1vette
Check those two wires that run over, then under, the advance plate in the dizzy. If vibration has caused the insulation to wear off, you may be grounding out the spark signal from that module. I've seen that happen on a stock distributor before.
Old Feb 12, 2019 | 04:04 PM
vark_wso's Avatar
vark_wso
Leif
Unless you have reasonably low cycles & high confidence in your starter from it's last refurbishing, posts 23 & 24 (solenoid) seem worthy of exploring at this stage. The contact & wheel on the plunger can get really cruddy with arc strikes. The intermittent nature of the problem could be due to the plunger wheel rotating somewhat upon each energizing ... hit a particularly bad spot on the wheel relative to the contact & resistance may be too high to overcome. Here's pic of my '66 327, similar problem last summer. Note the 'moon' shaped erosion of the contact's serrations & the arc-scarred surface of the wheel.
Jeff
Old Feb 12, 2019 | 04:46 PM
TimAT's Avatar
TimAT
Originally Posted by vark_wso
Leif
Jeff
I would hope he got this fixed by now-- this thread is from 2012
Old Feb 12, 2019 | 05:11 PM
rayL79's Avatar
rayL79
I had this problem with my 66 with a pertronix ignitor. Pertronix told me to bypass the ballast resistor and after doing that it has been perfect ever since. The only purpose of the ballast resistor is to prevent the points from burning up. If you don't have points, you should bypass it...the ignition pickup unit is looking for 12 volts, not 8 or 6. I would also recommend having the coil that is recommended by ignition unit manufacturer.
The ballast bypass will fix it.
Ray
Old Feb 13, 2019 | 11:35 PM
7T1vette's Avatar
7T1vette
FYI -- Some aftermarket electronic ignition modules want straight 12 vdc going to their box; some want the power coming from that [ballast] resistor wire. You have to read the installation instructions for whichever module you have to know how to wire it.
To Ignition problem, need help....
Old Feb 14, 2019 | 07:23 AM
derekderek's Avatar
derekderek
Vark, that is normal solenoid wear and has nothing to do with ignition when not cranking.
Old Feb 14, 2019 | 07:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Attack of the Zombie threads!!!!!
Jebby
Old Feb 14, 2019 | 09:34 AM
Big2Bird's Avatar
Big2Bird
Jebby
I have caught myself doing it with that "related thread." thing. I don't mind that feature. It's kind of handy. Sometimes they seem to meld a bit.
