DIY headlight actuator fix
Old Oct 8, 2012 | 09:55 AM
Surfer69's Avatar
Surfer69
Default DIY headlight actuator fix
I bought two actuators and for a while they worked fine then all of a sudden I started getting the lazy eye syndrome on one so did some tests and found one leaking.
I bought the repair kit which is just new rubber seals for the outer area but it doesnt fix the main diaphram. So I decided I'll cut it open since I read someone doing that before and see if I can fix. Using saw I made nice cut on back side and when openned sure enough diaphram had several holes like dry rot or something. These are new so must have been china crap or just sat on a shelf for many years, who knows.
Used some 3M window seal black stuff in orange tube to repair damage then sealed and taped the two halfs back together. Now it works perfect.
And another thing I noticed is the engine seems to idle better so these leaks can cause unnoticed problems that are hard to diagnose.
Old Oct 8, 2012 | 10:04 AM
oldalaskaman's Avatar
oldalaskaman
added to my favorites, many thanks
Old Oct 9, 2012 | 07:48 AM
VetteNURSE's Avatar
VetteNURSE
I had 2 new actuators (from china) go bad after less than 3 months. I only drive on weekends and not always at night. Norm at willcox took care of it.
Mike
Old Oct 10, 2012 | 04:25 AM
hunt4cleanair's Avatar
hunt4cleanair
What did Norm do? Replace or repair the units?
Old Oct 10, 2012 | 06:29 AM
VetteNURSE's Avatar
VetteNURSE
After a short discussion as to how I was testing the actuators and came to the determination they were both bad, Norm replaced both of them and sent a shipping label to send the others back at no cost to me. The new ones worked great. I did have to purchase the new ones and then recieved a refund after they recieved them, this took another call to confirm the actually got them back. Willcox does have some of the best customer service I have ever dealt with!
Mike
Old Oct 10, 2012 | 09:50 AM
Surfer69's Avatar
Surfer69
Another interesting discovery, now my run-on after shutdown is completely gone.
So when the question is asked "what causes run-on", in my case it's a vacuum leak. Don't know if that makes sense but it happened.
Old Oct 10, 2012 | 11:23 AM
oldalaskaman
excellent
Old Oct 10, 2012 | 02:57 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Last week we installed a vacuum pump in the receiving and shipping area.
All actuators, relays and other vacuum parts are now tested before shipment in an attempt to keep defects to a min. If the manufacturer won't test these prior to sending them to us, we will.
We feel that taking 5 extra minutes before shipping will save time and money for both you the customer and us the vendor... (not to mention the headaches). On a sad note.. I wish I had thought of this years ago.
Willcox
Old Oct 10, 2012 | 03:00 PM
0Willcox Corvette
Former Vendor
It does make sense if the wiper door is not moving far enough to break the contact on the limit switch.
Old Oct 10, 2012 | 04:11 PM
VetteNURSE's Avatar
VetteNURSE
Better late than never willcox. Goo thinking, I repeat great customer service
Mike
Old Nov 3, 2012 | 01:18 AM
Mariana's Avatar
Mariana
I love this thread, i just bought 2 "new" actuators. Cant wait to see em not work.
Old Nov 3, 2012 | 01:35 PM
0Willcox Corvette
Former Vendor
Mariana.. If you got them from us.. they have been tested before shipment.
Old Nov 3, 2012 | 08:18 PM
7T1vette's Avatar
7T1vette
God bless you for caring about your customers. It's nice that someone still does!
Old Nov 4, 2012 | 06:21 AM
scottw's Avatar
scottw
Willcox
Great customer service.
I have to get new ones also. Have to wait until after Christmas though.
Old Nov 6, 2012 | 06:41 AM
msdeess's Avatar
msdeess
Default Thanks!
Been putting that project off, your tip is next on my list!
Thanks!!
Old Nov 8, 2012 | 05:45 PM
Erniep's Avatar
Erniep
Default headlight problems
I installed bushings and gear in passenger side headlight. When I turn the lights on, one goes up and the other goes down. What did I do wrong ?
Old Nov 8, 2012 | 10:25 PM
0Willcox Corvette
Former Vendor
Ernie.. kind of lost as to "gear" but.. your problem sounds like the hoses are reversed on the actuator.
Old Nov 10, 2012 | 11:57 PM
augiedoggy's Avatar
augiedoggy
Well his profile says he has a 94 C4 so that may have something to do with it since the c4 uses gears.
Old Sep 14, 2013 | 02:21 PM
Surfer69's Avatar
Surfer69
Update:
Unfortunetly the repair would only hold for a few weeks so I broke down and bought new ones from Zip. Turns out these bad ones were most likely NOS (new old stock) that had been sitting for years rotting the salesman told me. Sounds exactly right so try and beware if buying new ones. ZIP ones are perfect so far.
To DIY headlight actuator fix
