duplicolor laquer.
Old Oct 9, 2012 | 04:41 PM
smyth1's Avatar
smyth1
Default duplicolor laquer.
anyone use that duplicolor laquer yet?one stage, no mixing,easy to spray,plus they have my color on the shelf.fathom green
Old Oct 9, 2012 | 05:02 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I would be interested in hearing about that paint also.
Old Oct 9, 2012 | 06:32 PM
longbros's Avatar
longbros
Yes, I used the Deep Blue Metalic on a 72 Harley Sportster. I was very happy with it, although I wound up with a fair amount of orange peel. I laid on plenty of clear coats, so I was able to sand out the orange peel. I think it had more to do with me being a novice painter, and less to do with the paint. Nice color, deep gloss.
Old Oct 9, 2012 | 07:09 PM
Doug1's Avatar
Doug1
its kinda pricey cuzz its thinned, if you have a real automotive paint store around you will get much more for your money. you are limited by their bank hours as opposed to the auto parts store. depends how much you need to paint, it doesn't go real far.
Old Oct 9, 2012 | 07:13 PM
Vette5.5's Avatar
Vette5.5
I used to shoot lacquer all the time as a kid, mostly for ease of use for an amature painter. It's not as soft, nor durable as modern two part paints, but easy to wet sand/buff out orange peel, and never used any clear coat. I always had the paint custom mixed at the automotive paint supply store, and mixing thinner in prior to loading the gun is no big deal. Can choose different thinner flash rates that way, and thinner is far cheaper than paint, too.
Old Oct 9, 2012 | 09:28 PM
markids77's Avatar
markids77
Easy to apply but not very resistant to gas or other solvents. A pretty good small project learning tool but I would be hesitant about refinishing a whole car with the stuff. By Federal Law the solids and VOC content is limited, and the weatherability of the paint will not be ideal. I would NOT choose this as a Corvette finish.
Old Oct 10, 2012 | 07:24 AM
daustin's Avatar
daustin
I used it to paint an ATV, came out looking just fine. If you don't use their clearcoat over it the base color dosen't have much shine.
Don
Old Oct 10, 2012 | 07:53 AM
Alan 71's Avatar
Alan 71
Hi,
I believe that since the cost of the paint used in most paint jobs is a relatively small part of the total out lay including other materials, preparation, application, and finishing time, it's a good idea to not let the cost of the paint determine which you use. Choose that which you believe is the best paint available.
People, including me, seem to like PPG acrylic lacquer.
Regards,
Alan
Old Oct 10, 2012 | 10:37 AM
oldalaskaman's Avatar
oldalaskaman
if you decide to use it , make sure you do a test spray on something similar to the item you want to put it on. painted my C4 fathom green and found that your idea of fathom green may not be what comes out of the can cause the paint makers idea of fathom green is a different shade. painted and sanded twice
Btw. the duplicolor single stage , dries shiny, so if you do your homework on technique, you can make a nice job. there are some excellent folks over in paint and body section.
To duplicolor laquer.
