heater control for 78/no ac
Old Oct 11, 2012 | 10:44 AM
jaisvette's Avatar
jaisvette
3rd Gear
Default heater control for 78/no ac
Does anyone know exactly what connects to the slider control on the panel marked
"VENT HEATER OFF" in a 78 Vette without AC ? Previous owner "installed" a radio/cd player, and butchered all the wiring and did not re-install the control lines for the heater!! Now the heat is on all the time, and there is nothing connected to that slider bar.
Old Oct 11, 2012 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe it's a bowden cable connected from the lever to the selector door. Do you have the assembly instruction manual (AIM)? The AIM shows the installation.
Old Oct 11, 2012 | 12:10 PM
BKarol's Avatar
BKarol
The 78 chassis manual shows it also on page 1a26. This is from the AIM if it helps.
Old Oct 12, 2012 | 10:42 AM
jaisvette's Avatar
jaisvette
3rd Gear
Thank you for the information. No one around here seemed to know or have info about the unit, but you did!!!
Thanks again, Jai
To heater control for 78/no ac
