383 Rotating assembly question
Old Oct 15, 2012 | 12:58 PM
81pilot's Avatar
81pilot
Originally Posted by keithinspace
When I started reading the thread, I was questioning your running with flat-top pistons without even considering the top end. Oversize valves or a large cam could lead to your wanting a little more clearance. Easy to accomodate now...tougher to accomodate after you've made the investment.
I hear ya. Thats why I went around the horn and came up with the dished. I could go flat top, but I would need a 76CC head. I can run the 12CC dished with the 70's . And go up in cam later if I want to and still have the room like you said. My original assessment of flat tops with 64's were going to raise the compression and give me possible detonation and driveability problems down the road, and for a driver I don't need that. The spec I have now will make it fun and still have ample power for some fun track time.
Old Oct 15, 2012 | 01:17 PM
gkull's Avatar
gkull
You could get by with I beams no problem unless youre stuck on the heavier rod
5140 cast crank
Youll need smaller than 70cc to get 10:1
I think the avg FT piston with 3cc(??) relief with 64cc and .005 in the hole might get you 10, 10.3 depending on head gasket. Off top of my head figures so they wont be exactly accurate but in the ballpark
383 with flat tops and 64 cc is more like 10.7 and requires lots of cam duration to run on pump gas. 70 -72 cc heads bring it down to a reasonable compression level
Old Oct 15, 2012 | 03:54 PM
81pilot's Avatar
81pilot
Originally Posted by billla
One of the Scat balanced kits is the best buy if you're going with a cast crank. IMHO, a cast crank -> hypereutectic pistons; I don't see the value in forged pistons with a cast crank - if you need forged pistons from a power-adder or HP perspective...then you need a forged crank. It can also make balancing interesting, as the bobweight is a fair bit different. Avoid Eagle cast cranks, period.
As for design, it all has to work together - so just start fitting together all aspects of the design...just don't BUY anything until the design is DONE.
I sometimes end up with guys having expen$ive "leftover" stuff because they get excited and buy parts before the design is frozen...even when I tell them specifically and with emphasis not to. It's a sure way to end up spending more $$$.
OK, I have one question, how do I know the volume head I need? like 200,220 or 235CC?
Old Oct 15, 2012 | 04:05 PM
billla's Avatar
billla
St. Jude Donor '14
It sounded like you were trying to build the engine around a set of heads you already had (RHS)...?
The short answer, and I'm sure there will be many perspectives, is that you're looking for the smallest intake runner size that will deliver the flow needed to hit your power targets. This is where the quality of a head will really show - AFR for example will deliver more flow from a 180cc runner than other companies can make with 220cc runner. Port cross-section has a major impact on low- to mid-range throttle response - so you do get what you pay for.
Happy to share more detail via PM, but I don't enter into the huge pizzing matches on this stuff in the public forum any more
Old Oct 15, 2012 | 08:05 PM
Crepitus's Avatar
Crepitus
Looks good; An aluminum head will help at the track, 40# of hight nose weight is significant. For a little more comin out of the turns you may ask Comp about grinding you a 268 on 108 lca vs the 110 it will improve mid tork but cost a little vacume and top end. +5hp early in the straight will beat +40hp at the end every time.
Old Oct 15, 2012 | 08:11 PM
garygnu's Avatar
garygnu
aluminum heads allow you to run a higher static compression.the runner sized you want is some what determined by engine size and where you want to make the power.the smallest runner will great low end power but limit all out HP with your 383.the 220 runner I feel is best suited for street and strip .the biggest 235 runner would be nice for big cubes and high rpm HP.have you considered a 3.875 crank ?
Old Oct 16, 2012 | 09:20 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Good info on port sizing.
http://forums.corvetteforum.com/c3-t...ce-builds.html
http://www.dartheads.com/tech-articles/port-volumes/
Old Oct 16, 2012 | 10:42 AM
63mako's Avatar
63mako
As for port sizing the huge increase at low RPM with a small (180) port is overblown. Look at the back to back dyno testing in the Dart article above. It is back to back testing on a similar 383 to the one your planning. AFR 195 is the best head for your application. If not AFR 195 look at a different 195-200 port size. A lot of the drop off in low RPM and throttle response noted with large port heads can be attributed to the lack of available dual plane intakes with the large intake port. With the recent increase in building large CI SBC engines (427-434) requiring a larger port head the need for a Dual plane with 215-245 cc port sizes will soon move intake manufacturers to designing new intakes geared toward that market.
Old Oct 16, 2012 | 02:38 PM
Crepitus's Avatar
Crepitus
Two excellent resources. The AFR 195 is the best all around street head on the planet. It has the best balance of size (velocity) and flow. stock architecture.
Old Dec 7, 2012 | 05:36 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Default compression
What I have so far(on paper)....12CC Dished pistons, 70CC heads with a .015 gasket(fel pro 10094 steel embossed gasket) and a .020 deck, thats keeps me from needing the block decked. I will need to use 6 inch rods and short skirt pistons. But that should get me at 9.78:1( I wanted it a tad lower than my initial after more research and how I want to drive it)
And using a Comp cams 268H Cam I can get by with my stock rear end for now and stock converter, but I plan a new converter while the engine is out, may go 2200 stall. And eventually a new rear gear, but I can recam at that point if I need to. This cam will make the power where I want it and the intake will work well with it.
The heads I am looking at are RHS aluminum 70CC and I will put 202-160 SS valves in them with springs that will handle lift up to .525 lift if I ever decide too in the future. I already have the valves and associated parts. Probably will go with roller tipped rockers. All of that should net about 450 HP if I calculated right, but it should be a fun driver and run easily on pump gas. I will use I beam rods, and a cast stroker clearanced crank internally balanced. Performer RPM Intake, with my recently rebuilt Qjet on top. That with my headers and 2.5 true duals I already have should flow well and run good. If anyone sees an issue with this setup please let me know. Thanks!
Are you sure about the CR at 9.78, seems like with the specs you wrote the compression would be lower.
Old Dec 7, 2012 | 06:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
These are 170cc heads on a 383 ?
