HELP !!! QUICK CAM QUESTION!!!
Old Jun 4, 2002 | 10:34 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default HELP !!! QUICK CAM QUESTION!!!
Ok I installed a new cam and heads on my car. I go and start the car up and it runs like poopie, needs almost half throttle to keep it goin. Could I have put the cam in 180 degrees off. I install it according to the instructions, the 2 dots closets to each other but could have I flipped the cam gear backwards and put it 180 off? This is really maken me sick and I know someone in here can help me. :U :cry :cry
Old Jun 4, 2002 | 10:43 PM
Pete79L82's Avatar
Pete79L82
Default Re: HELP !!! QUICK CAM QUESTION!!! (DCBStingray)
The cam can not be installed 180° off. The cam turns at 1/2 of crank speed so for every turn of the crankshaft the cam only turns 180°.
The first thing I would check it the timing to be sure it is correct along with the firing order to be sure that you didn't get any of the plug wires on wrong.
Then I would check to be sure you do not have a valve with the lash set to tight. That would require a higher RPM to keep running.
Old Jun 4, 2002 | 10:47 PM
DavidOrr's Avatar
DavidOrr
Default Re: HELP !!! QUICK CAM QUESTION!!! (Pete79L82)
Careful I flattened a cam lobe because I set my lash to tight. Same symptoms as you've described
Old Jun 5, 2002 | 12:25 AM
C5kid's Avatar
C5kid
St. Jude Donor '12
Would having the valve lash too tight make it back fire and make it extremly too hard to start? Cause this whole setting the valves is givin me a head ache, any one have tips on setting the start up valve lash? It is a hydralic (sorry 4 spelling) cam.
Old Jun 5, 2002 | 12:30 AM
Pete79L82's Avatar
Pete79L82
Having an intake valve set too tight will cause it to backfire throught the carb because the valve may not be closing completely. Having any valve too tight will cause hard starting and a very poor idle.
[Modified by Pete79L82, 10:30 PM 6/4/2002]
Old Jun 5, 2002 | 11:18 AM
zwede's Avatar
zwede
I recommend you set the valves the **** way:
With both valve covers off, rotate the crank and watch the rocker arms on cyl 1 and 6. As you come close to TDC you will see the rockers of cyl 1 OR 6 move. The other cylinders rocker pair will not move. If #1 moves, rotate the crank one full turn. If #6 moves, you're set. With the timing mark aligned with zero on the tab, adjust both rockers on #1.
To adjust, loosen the nut until you can wiggle the rocker up/down. The "spin the pushrod" method is unreliable. Once you can wiggle it up/down, tighten slowly until the play is just gone. Now tighten an additional 3/4 turn.
Rotate the crank 90 degrees (1/4 turn) clockwise. I recommend putting a dab of paint on the front of the pulley as it makes it easier to turn the 1/4 turn.
Adjust the next rocker pair in the firing order, #8. Turn crank another 90 dgr and adjust #4 etc. Firing order: 1-8-4-3-6-5-7-2.
This takes longer to do than the method in the manual, but your chances of success are far greater...
Old Jun 5, 2002 | 01:33 PM
DavidOrr's Avatar
DavidOrr
Default Re: HELP !!! QUICK CAM QUESTION!!! (zwede)
zwede,
My stupid question for the day. If the cam is an aftermarket cam, which I am assuming it is - is this method still valid?
I'm not a cam expert by any means, however won't the charactistics of the cam be different possibly causing problems when rotating the the crank 90 degrees.
When I set mine, the second go around, I followed CompCams instructions. Which were to crank the engine and watch for movement on the exhaust. When the exhaust begans to move set the intake. They also recomend the "spin the pushrod" and I agree the up/down is better. Then continue cranking the engine until the intake has almost completed a full up/down stroke and set the exhaust.
The method you recommended should put you on the compression stroke, correct? But depending on the cam - would this always be true?
Just trying to understand the vast world of cams - life was much simplier with my pontiac 400's - you simply torque the rockers to spec and walk away.
-david
Old Jun 5, 2002 | 01:39 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: HELP !!! QUICK CAM QUESTION!!! (DavidOrr)
no mater the cam, the firing order, and therefore the order of it opening and closing will always be the same (for the same engine).
It may be that you have the distributor 180 degrees off, or maybe even 1 tooth off.
You may want to make sure to get the #1 cylinder at TDC, and then pull the distributor cap and make sure the rotor is pointing to when #1 should be.
Hope this helps.
Old Jun 5, 2002 | 05:28 PM
C5kid's Avatar
C5kid
St. Jude Donor '12
Ok I re-adjusted the valves and now it seems to go better but you have to have the throttle help wide open to get it to idle and then it will just shut off even. WTF!!! I m getting really sick of this, I am goin to pull the distrubtor out and get it on TDC and make sure every thing is in perfect.
Old Jun 5, 2002 | 05:32 PM
Fevre's Avatar
Fevre
sure your efi is hooked up right and working properly? You should not have to throttle an efi system to get it to idle.
Old Jun 5, 2002 | 10:18 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
DCB, what is your timing set at? If it's close to where it should be, you can save yourself the trouble of r&ring the distributor and look elsewhere for a solution. If you can't get it close to where it needs to be, then the distributor has been installed wrong and needs to be redone.
Old Jun 5, 2002 | 10:29 PM
subboz's Avatar
subboz
By looking at all these post if it was carbed I would say rebuild or check the carb. But so many problems are related to the EFI units and if you installed the cam after the efi unit was running there may be a possibility you need to readjsut the program or in some systems get a new chip.
To HELP !!! QUICK CAM QUESTION!!!
