1978 With a Vibration.
Old Oct 16, 2012 | 03:14 PM
25anniv's Avatar
25anniv
Default 1978 With a Vibration.
Hi i have a 78 with a vibration at around 70mph rattles the dash. If i let up on the throttle just a little the vibration goes away. im going to have the tires checked for balance then re balance. if it is a drive line issue is there any way to tell if its the drivshaft or half shaft ?? Any help would be excellant thanks.
Old Oct 16, 2012 | 03:23 PM
PhotoVette1's Avatar
PhotoVette1
Can happen if rear wheel camber is off. Park in a level spot and see if your back tires are pretty much straight up and down.
Old Oct 16, 2012 | 03:26 PM
MelWff's Avatar
MelWff
Try placing the shifter in neutral at 70mph and let the RPM drop. If the vibration goes away the source is engine related.
Old Oct 16, 2012 | 06:21 PM
johnt365's Avatar
johnt365
I had this same issue on my car. I needed new tires anyhow due to wear. So I ruled them out. In short, I didnt find the issue till swapped the torque converter. I noticed that one of the Ujoint straps on the drive shaft had come off. I went ahead and took that opportunity to replace all the ujoints.
All I am sayin is a visual check under there would have helped my issue with the missing strap. I never would have guessed that to be a possibility.
Old Oct 16, 2012 | 09:23 PM
dgood's Avatar
dgood
I had the same problem at about 60 and it was my harmonic balancer. Do what melwff said and see if the problem goes away in neutral.
Old Oct 16, 2012 | 10:55 PM
flameorange76l48's Avatar
flameorange76l48
i have the same problem on my 76, i havent had the tires balanced yet but i did notice that mt drivers side rear wheel is leaning in on the top and the passenger side is straight which is right and will this cause a vibration?
Old Oct 16, 2012 | 11:43 PM
PhotoVette1
It sure did on my '77.
Old Oct 17, 2012 | 11:04 AM
BHRIG's Avatar
BHRIG
I know this is "off the wall",check to see if your exhaust is touching anywhere.
You could have vibration from the exhaust.
Good luck
Old Oct 17, 2012 | 12:18 PM
pauldana's Avatar
pauldana
ether the rear end bushing is bad gone or loose, or you need a drive train alignment.
http://forums.corvetteforum.com/c3-t...lso-still.html
Old Oct 22, 2012 | 07:47 PM
25anniv's Avatar
25anniv
Have not been under car for awhile trailing arms have been serviced tie rod arms have been replaced. last year replaced front end ball joints, control arm bushing, frt rotors and any other rubber parts. if it is this rear end bushing where about is it ? how do i know its bad ? can i do the job myself ? thanks for your help
Old Oct 23, 2012 | 10:47 AM
gcusmano74's Avatar
gcusmano74
Camber on the rear wheels should be slightly negative; they should lean in at the top. On a level piece of pavement, about 1/8" to 3/16" in from plumb vertical is about right, when measured at the wheel rims.
If you take your measurements exactly 14 5/16" apart, 1/4 inch equals one degree.
To 1978 With a Vibration.
