LS1 Swap
Dirty Dingo Mounts.
Batwing oil pan
going in
A tight squeeze between the frame mounts
Finally in
Passenger side fit
Driver's side fit
The original small block chevy was about 1-1/4" from the firewall. Not the best pic but the LS1 is about 1-1/2". The Dirty Dingo mounts put the engine right where I wanted it.
Plenty of room down below
Started putting on the accessories. This bolt touches the driver's side frame mount. an easy fix
Good clearance below the alternator
The passenger side exhaust manifold looks good
I am amazed at the fit. Looks like it is designed for it.
A shot from below on the driver's side. Good fit around the Jeep steering box.
All accessories installed
Cleaned up the remains of the factory crossmember. This WAS a 4-speed car
This is what worried me. The Bowtie Overdrive crossmember did not fit. The transmission tailshaft lays on the tube and it still has about 7/8" to drop to sit on the saddle
Spoke to Bowtie Overdrives today. They said I received the wrong crossmember and they are sending a new one. This is the crossmember I received
This is the crossmember they are sending to replace it
Working on this project is hit and miss. Want to mount the Vintage Air evap assy in the car this weekend and look at heater hose connections at the water pump.
Btw Vetteworks has the collector/donut seal/flange for those manifolds.
http://www.vetteworksonline.net/cata...p3trosf5i8mlp0
1. cut my own in the Model Shop at work OR
2. I have three (3) sets of C5 h-pipes at the house.
I'll probably just rob a set of one of the h-pipes.
Forgot to mention there are more pics in my blog. Follow the link in my signature.
They don't have the same mounts I bought listed but I bet if you called they would cut some for you.
In the box
The Vintage Air instructions are not the best in the world. Being a working Engineer, I realize how difficult it is to author instructions. They ought to use more actual photos instead of illustrations.
I taped their templates to the OEM opening in the firewall. The template marks where to drill holes in the firewall.
After drilling the holes:
I was not careful while using a vice grip clamp the front of the evap assay in place while I worked on the engine side of the firewall. I cracked the windshield
Vintage Air designed this cover to seal the OEM opening. It mounts on the outside of the firewall:
I am going to mount this on the INSIDE. I plan on working on the firewall anyway. I will smooth the opening to the cover then. My template:
The fit:
Observations:
1. I trimmed the lower left-hand corner
2. Trimmed the upper right-hand edge
3. I need to remove the OEM fastener at the bottom right of the opening.
4. Notice the clearance notch in the blue circle? The notch is not centered over the OEM home. That hole is one of the key mounting point for the Vintage Air evaporator. When I mount the assy using that hole, the evap is too far to the left.
I am going to modify the Vintage Air rear bracket to shift the evap assay to the right. Should have taken more pics but I was bummed out after cracking the windshield.
I am converting from 4-speed to 4L60E I could use a little more clearance in this area. Did factory automatic cars have this?
