With the block out at the machine shop, it's time to pick out a new clutch. It's a 1980 with the original 4 speed. The engine will be around 400 to 425 HP and it's just a street driver, no track. With 400 HP, I am thinking that just a stock Napa clutch is not really an option. So, who can recommend a good street clutch that can handle 400HP?
I used the McLeod Super Street clutch. They claim about 30% holding power than stock. Slightly higher clutch effort. For my L-48 it has worked fine. You might want the next step up for that kind of power. Good company, good clutch.
Several recent threads on this. Mcleod and Zoom have been mentioned. I chose a Centerforce dual friction. The CF II is also a good choice. They are the same pressure plate, just different discs. It has a pedal force close to original but clamps down hard.
I did search some recent posts and the Centerforce seemed to be the way to go. Pedal pressure close to original is preferred and since I am not at 500HP, just the 400HP mark, I thought I would look for some more input. Thanks
I use a CF DF and love it.
I dont know my power level, had est from 550 to 617 so who knows.
Holds it like theres no tomorrow and a nice pedal to boot.
Think most put "too much clutch" in their cars and get turned off with their bad manners on the street could be wrong though.
Probably 95% of the people on this forum could run a stock clutch with no problems. Think of it this way, street tires are going to break loose long before the clutch will ever slip.
The Napa probably would hold, I just don't want to bet on it. LOL
If yours at 550 and hold well and at best mine is at 430, then the DF is getting ordered. Also, I certainly didn't want a pedal that takes the strength of ten mighty men to push down.
I would use a stock replacement clutch. The big name brand in my area is Luk. Even a no name re-man. would be ok for street driving. My experience with these has been good and you can put the money saved elsewhere on your Corvette.
The unit I found when I removed the tranny was a Perfection (Zoom?). It really didn't hold up well with the L48, 195 HP engine. I have no delusions that it would hold up with 425 HP.
I use the Hays street/strip disc, with an antique GMPP PP in my 61.
I tried a Luk, but after a few hot shifts it would soft shift(unable to spin tires) .
Ran the Luk PP with the hays for a few years anyway. The Luk was 5# lighter!
Bottomline:
I'd use the hays street/strip disc with hays STREET PP. easy pedal and can take the heat better.
I run Centerforce Dual Friction clutch and Fidanza aluminum flywheel. While I don't use my vette as a daily driver, adding a T56 6 speed and hydraulic clutch made it much better for the street. It's amazing what the difference is with gearing
If you want a "hot street clutch" no problem... get one. I have never had a problem with a quality "OE replacement" when installed properly with new pilot bushing and resurface flywheel.
I never had a problem with a stock clutch hold up, that includes in a very strong big block Camaro with 4:56 gears, slicks and multiple trips to the strip.
Bottomline:
Thanks for the info, it's nice to get useable feedback. The engine builder also listed the Hays as one that he prefers
