MY 75 on Friday went out to clean for a local show on Sat,
any no sound what so ever,The inside light is on when door open,
key buzzer is on but when try to start no sound what so ever,
But I can start with a screwdriver, any help I know this is the place for
some good info,
Neutral start switch is defective or out of adjustment....or starter solenoid coil has failed 'open'.
OR clutch switch - manual trans, or starter switch, or wiring or weak battery, or bad ground to engine(probably not since it will jump), or ......
Get a meter or at least a test light and check S terminal (purple wire) you are jumping with a screwdriver. If power is not there when key is turned, work your way back until you find it. It helps if you have a wiring diagram.
