Suspension issue? Opinions?
Old Oct 22, 2012 | 10:00 AM
vettebuyer6369's Avatar
vettebuyer6369
Default Suspension issue? Opinions?
I've got a wobble/ vibration that is noticeable at 50-55 MPH. Always the same speed. Alignment shop doesn't think that's the problem. One guy guessed a bent wheel, another thinks there's a rear end problem.
Obviously the wheel issue is easily tested/ruled out if I can borrow some wheels.
Any input/guesses/opinions?
Old Oct 22, 2012 | 10:06 AM
MrJlr's Avatar
MrJlr
I had a similar problem on a Camaro....new tires (and my old ones weren't that old) solved it...
I really didn't think my tires were bad....but new tires and the wobble went away...
Old Oct 22, 2012 | 10:20 AM
oldalaskaman's Avatar
oldalaskaman
static imbalance? try road force balance ?
Old Oct 22, 2012 | 10:47 AM
Les's Avatar
Les
If you can't borrow a set of fronts to swap on there, how about switching sides with using the two fronts that are on now. If that changes the way it feels, it probably eliminates suspension and points to the wheels. By the way, if you have a bent wheel it should be evident when putting that wheel on the balancing machine. If you remove the wheels from the car and take them to a tire shop, they may be willing to spin them for no or minimal charge. Good luck.
Old Oct 22, 2012 | 11:13 AM
oldalaskaman
could be a separation, inside one of the tires. not as common as it used to be , but still happens
To Suspension issue? Opinions?
