View Poll Results: What should I do since I'm this far?
Pull the engine, minor rebuild, because it won't hurt only help
9
36.00%
Pull the engine, reseal it, paint it and put it back in
3
12.00%
leave it in.. do it when it really needs it
13
52.00%
Voters: 25. You may not vote on this poll
Pull engine now or wait?
Old Oct 22, 2012 | 10:42 AM
wyocat's Avatar
wyocat
Default Pull engine now or wait?
OK here is my dilemma, the 68 (327 350HP) currently the transmission, bell housing and clutch out for replacement. Trans was in great shape but put new bearings, bushings and brass in just because the car has 76,000 and thought was good idea. Now what about the engine, since I'm this far should I
1) Pull it to put in new gaskets and rear main seal along with rings and bearings and freshen everything up. (compression is good).
2) Pull it and new gaskets, rear main seal and valve stems... and back in.
3) Leave it in.
Problem is with my other projects I really can't afford to do all the machine work for a complete rebuild, at best just rings bearings gaskets and maybe valve job. Of course we all know they always take more than we plan.
John
Old Oct 22, 2012 | 11:38 AM
AirborneSilva's Avatar
AirborneSilva
Sounds like a good winter job.
Old Oct 22, 2012 | 12:21 PM
billla's Avatar
billla
St. Jude Donor '14
The most expensive phrase in the human language is "While I'm in there..."
Old Oct 22, 2012 | 12:29 PM
johnt365's Avatar
johnt365
To me, pulling the motor while the transmission is out is a huge side stepping "while I am at it". They are not really related and that motor is going to eat up a whole lot of time.
I would go ahead and replace your u-joints while you are there, but not rebuild the motor. You are only talking about 6 bolts holding the transmission to the motor right?
I would wait till there is a better reason and it really needs it. You arent losing anything just because the trans is out. Well, 6 bolts or so...
Old Oct 22, 2012 | 12:50 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
"If it ain't broke, don't fix it."
Old Oct 22, 2012 | 12:52 PM
wyocat's Avatar
wyocat
That is so true!
Car sat from 1981 till August of last year. To date I have only put about 25 miles on it since getting it running so really not sure of leaking condition other than the the underneath side of the chassis and oil pan shows signs of "standard" leaks in the past. I know valve seals will need replaced soon, although at this time not seeing the "smoke at start-up".
I just go back and forth on this... I feel like I'm running for election!
Old Oct 22, 2012 | 12:59 PM
johnt365's Avatar
johnt365
What do you find more fun, working on your Corvette or driving it? That may help.
Old Oct 22, 2012 | 01:03 PM
TWINRAY's Avatar
TWINRAY
No brainer for me, if it's out at least take the heads off and look at the lifters and cylinder walls - that will get you started. Mine, on my '69 eom 350/300 about 4 lifters were set to really go at 90K miles. Question is, do you want to pull the engine again to do some work. I'd fork over the money now to at least get it "mildly refreshed" before I'd put it back. I don't agree with the "if it ain't broken ... " comments - but that's me.
Old Oct 22, 2012 | 01:12 PM
johnt365's Avatar
johnt365
The motor is not out though...
Old Oct 22, 2012 | 01:14 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
25 miles in last 30+ years. Good compression, I would pull it, pull heads and pan. Replace timing gears, cam, lifters, valve seals, gaskets, rear main seal, repaint, clean at a minimum and button it up if the cylinders look good. Your talking a couple days work and $400.
Old Oct 22, 2012 | 01:23 PM
SuperBuickGuy's Avatar
SuperBuickGuy
ya know, once you have the motor out, you might as well drop the frame and powder coat it
do post pictures
Old Oct 22, 2012 | 01:26 PM
MrJlr's Avatar
MrJlr
I voted for "Pull the engine, reseal it, paint it and put it back in"
With the trans out, it will pull straight up in an hour or two...
Gaskets & paint...afternoon job....and she'll be all sealed up and looking like new! And no drips in the garage!
And yer not talking about much money either....$150 ???
Old Oct 22, 2012 | 01:28 PM
SuperBuickGuy
okay, you made me laugh..... while my gaskets don't leak on my Corvette, the *&^*%%*!!! oil pan drain plug does - I think with older Corvettes you have to take a more relaxed view of oil spots and simply say (like the VW folks, and Harley folks) it's marking its territory.
Old Oct 22, 2012 | 01:37 PM
MrJlr's Avatar
MrJlr
They don't "have" to leak !
Old Oct 22, 2012 | 04:01 PM
wyocat's Avatar
wyocat
True..
I find that they generally stop leaking when they are out of fluids.
Old Oct 22, 2012 | 04:11 PM
wyocat's Avatar
wyocat
do post pictures
That is true as well..
and as a fellow Buick guy we all need reasons to "add on projects". I would actually have to put my 455 in the Skylark to free up my stand!
Old Oct 22, 2012 | 05:13 PM
SuperBuickGuy
Some people think I speak in the hypothetical, au contraire says I.... don't ask me why I am building a twin-turbo, efi, girdled, custom piston, custom rod 455 monster. I still haven't even purchased its home....
and good point about how to get them to stop leaking - but in my experience, they still leak when they fling a rod or two out the side
To Pull engine now or wait?
Old Oct 22, 2012 | 06:13 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
After all of that time sitting since being run, I'd pull it and do the above, plus inspect at least the front main and #1 & #2 rod bearings. And, if you have access to a valve spring tester, I'd check them too. Do bear in mind, budget constraints aside, that an issue which ought best be addressed before you put it back together may present itself. If so, I wouldn't turn a blind eye to anything important, even if it means more down-time.
Old Oct 22, 2012 | 06:28 PM
TheSkunkWorks
FWIW, another long time Buick guy here. Happen to have "engineered" the first ever Moldex billet-cranked 500+ CID BBB long before credit was being given to others, and still have the original prototype, complete with BBC journals...
Sorry about the sidebar. Just don't meet too many Buick guys.
Old Oct 22, 2012 | 06:34 PM
MrJlr's Avatar
MrJlr
True..
