View Poll Results: What should I do since I'm this far?
Pull the engine, minor rebuild, because it won't hurt only help
9
36.00%
Pull the engine, reseal it, paint it and put it back in
3
12.00%
leave it in.. do it when it really needs it
13
52.00%
Voters: 25. You may not vote on this poll
Pull engine now or wait?
Old Oct 22, 2012 | 07:20 PM
Les's Avatar
Les
Originally Posted by wyocat
True..
I find that they generally stop leaking when they are out of fluids.
Old Oct 23, 2012 | 12:49 AM
Vette5.5's Avatar
Vette5.5
Since you're planning on pulling the engine anyway, may as well do it now. Never a good idea pulling heads and things, with the engine still in the car, as could risk scraping up body paint. Plus, much easier cleaning/painting things up, under the hood. Not sure of your room/set up, if have the room to drop the 455 into your Buick, but could either borrow another stand, or store it on wood blocks.
Old Oct 23, 2012 | 01:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
If youre happy with the way it runs nows the time to pull it
Clean paint then you can detail the engine compartment so it looks new.
Doesnt take a whole lotta $ and is worth it every time you raise the hood.
Old Oct 23, 2012 | 03:13 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Originally Posted by SuperBuickGuy
okay, you made me laugh..... while my gaskets don't leak on my Corvette, the *&^*%%*!!! oil pan drain plug does - I think with older Corvettes you have to take a more relaxed view of oil spots and simply say (like the VW folks, and Harley folks) it's marking its territory.
I have a Harley and it does NOT leak anything......
Old Oct 23, 2012 | 07:41 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Problem is with my other projects I really can't afford to do all the machine work for a complete rebuild, at best just rings bearings gaskets and maybe valve job. Of course we all know they always take more than we plan.
John
If you pull that engine now with 76K miles, you will soon find out that you will indeed need to do a lot more than you are planning. No sense pulling the engine and doing it half right or half wrong. I'll stick with the 'if it ain't broke.....' philosophy until such time that you are in a position to do a complete rebuild either by choice or forced into it.
Old Oct 23, 2012 | 07:30 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've actually got a BBB sitting on a wood cradle right now, consisting of a couple of 4x4 blocks bolted to a 2x12 and attached to the motor mounts. Having done a few of them over the years I've found that with a little forethought they work quite well. My bare blocks are just stored on end.
Old Oct 23, 2012 | 09:15 PM
Vette5.5's Avatar
Vette5.5
Actually, have a couple 4 wheel furniture dolly's, and had a BB stored on one of these for years. Was in a patio storage shed, so out of the way. Had the Home Depot rip a 4x8' sheet of plywood in half, so could roll it accross the lawn.
