Is this right??? BB Manifold Question--
Old Jun 5, 2002 | 09:40 PM
JB's Avatar
JB
St. Jude Contributor
Default Is this right??? BB Manifold Question--
Getting ready to put the manifold back on (ain't it pretty?), and I noticed that the upper oil passage in the middle of the picture below is only covered by gasket material, not by the manifold. Can that be right? What the heck keeps it from leaking? I realize I'm probably demonstrating massive ignorance here, but that just don't seem right to me.
JB
Old Jun 5, 2002 | 10:50 PM
jyounane's Avatar
jyounane
Default Re: Is this right??? BB Manifold Question-- (JB)
I've had my manifold on and off a few times, the manifold looks like yours......my heads don't have that oil port, it sure doesn't look like that.....when the manifold bolts up.
Joe
69 427L36 M21 3.08 White Coupe
Old Jun 5, 2002 | 11:20 PM
JB's Avatar
JB
Default Re: Is this right??? BB Manifold Question-- (jyounane)
Oh, crap. That's right where the damned thing was leaking, too. Has this thing got the wrong heads on it? Here's a pic without the manifold. Anybody?
JB
[Modified by JB, 9:21 PM 6/5/2002]
Old Jun 5, 2002 | 11:43 PM
jyounane's Avatar
jyounane
I can show you a picture of my manifold / heads. Do you have an email address I can use, I don't know how to post pictures here yet.
Joe
Old Jun 5, 2002 | 11:57 PM
PRNDL's Avatar
PRNDL
I cant tell from the picture what you are talking about. What oil passage?
ohhhh... that hole above (in the pic) the intake manifold......hmmmmm.
[Modified by MNJack, 10:58 PM 6/5/2002]
Old Jun 5, 2002 | 11:58 PM
73 LS-4's Avatar
73 LS-4
What you should be looking at is your heat crossover passage, no oil circulates through the intake. Are your head casting numbers correct? My heat crossover looked nothing like that and was only the size of the heat crossover port on the intake manifold (I'm running a 68 L-36 intake).
:cheers:
Pat Kunz
Old Jun 6, 2002 | 12:01 AM
PRNDL's Avatar
PRNDL
Default Re: Is this right??? BB Manifold Question-- (73 LS-4)
Pat, I think he is talking about that gaping hole between the intake manifold and the valve cover in the top pic (dont look at the intake manifold itself)
JB, While we are checking, what is the # on the intake? MJ
Old Jun 6, 2002 | 12:11 AM
bigvette1's Avatar
bigvette1
JB,
No that does not look right. But, maybe someone that has set and intake on BB heads without the gasket can tell. The heads appear to be standard BB large oval port heads. Post the head numbers (under the valve cover) and the manifold number (stamped on top 6 digits) and we can tell. Is this the origional intake?
Old Jun 6, 2002 | 12:19 AM
jyounane's Avatar
jyounane
Incidentally, your photo of the heads looks familiar. I think mine could actually be the same. That top port reduces heat from coupling from the exhaust crossover to the head. It is probably simply covered by the gasket. I think the top port above the round exhaust crossover port is not connected into the oil space anywhere and probably should not leak.
Perhaps you could have a closer look.
I don't think the heads or the manifold are wrong.
I have emailed a photo of mine.
Joe
Old Jun 6, 2002 | 12:26 AM
oger's Avatar
oger
The top cavity does nothing. It is covered by the gasket and is a good place for liquids to find there way into. That is why you thought it was an oil passage.
Old Jun 6, 2002 | 01:00 AM
JB's Avatar
JB
Default Re: Is this right??? BB Manifold Question-- (oger)
That's what I wanted to hear! Thanks, guys. Joe, thanks for sending the pic of your manifold. The top and bottom cavities are both oily, which is what made me think they were both oil passages, but then my gaskets were leaking, which is why I pulled the manifold in the first place.
The number on the intake, BTW, is 8947801 (hmmm, that's seven #s, not 6?). I'd pull the valve covers and get the head #s, but I'm just too darned tired. Tomorrow.
I gotta chill out. I'm taking this stuff way too seriously! I never got panicky about my '78 like this. I wonder why that is? :D
JB
[Modified by JB, 11:03 PM 6/5/2002]
[Modified by JB, 11:11 PM 6/5/2002]
Old Jun 6, 2002 | 03:02 AM
427_Roadster's Avatar
427_Roadster
Learn something new about the 'Vette every day. Just looking at a picture of my L36 and you can see the extra gasket material in that same area.
Hope it helps you chill some! :D
:cheers:
Tom
Old Jun 6, 2002 | 09:55 AM
bigvette1's Avatar
bigvette1
Default Re: Is this right??? BB Manifold Question-- (427_Roadster)
:cheers:
Tom
How true. Went out and felt the extra material and the indentation in the head. Sure makes you think and look hard when you put the intake on without a gasket and wow a hole.
To Is this right??? BB Manifold Question--
