WHAT IS IT??
Old Jun 5, 2002 | 11:09 PM
OkeeGuy's Avatar
OkeeGuy
Default WHAT IS IT??
what is the "diaphram" looking thing (looks like a flying saucer) under the glovebox...it has a vacuum hose conected to it...
Old Jun 6, 2002 | 12:11 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: WHAT IS IT?? (SIGNGUY)
It's the Vaccum canister which opens and closes the door from the heater core I believe!
Old Jun 6, 2002 | 12:33 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: WHAT IS IT?? (Mike69)
ok...thats what i think too...i have read to rivit that door closed to reduce engine heat from comming in (i live in florida)
im wondering what happens in that case...do i also disconnect the hose??
Old Jun 6, 2002 | 08:54 AM
Ybnormal's Avatar
Ybnormal
Signguy,
I think that is what it is also. If you do unhook it, be sure to plug the hose with something like a golf tee or small screw or you will have a vacuum leak in the system.
YBNormal..drive a Vette
Old Jun 6, 2002 | 09:02 AM
Edzred72's Avatar
Edzred72
I believe it closes the flap, inside the vent, to isolate the cabin from the core. It provides you with recirculated cabin air. Part of the A/C system.
:D
To WHAT IS IT??
