coil spring compressor
Old Jun 6, 2002 | 06:40 AM
stingraynick75's Avatar
stingraynick75
Default coil spring compressor
I rented a spring compressor but it would not fit in the shock hole, and there is no way to get a outside comp. to work, is there a special tool to use or will one from "Harbor Freight" work with modifacation? :smash:
Old Jun 6, 2002 | 06:58 AM
1979toy's Avatar
1979toy
Default Re: coil spring compressor (stingraynick75)
Most internal spring compressors have to be fully disassembled and reassembled inside the spring. Could that be your problem?
Old Jun 6, 2002 | 09:12 AM
Flareside's Avatar
Flareside
I use a 2' long threaded rod and a 6" square metal plate. $10 from Home Depot or Lowes. Look up the old posts here on the forum about "spring compressor" for details and pictures.
To coil spring compressor
