Rear Gear Question
Old Jun 5, 2002 | 02:55 PM
Koz
Guest
Posts: n/a
Default Rear Gear Question
My car has the 3.08 stock gears and she's leaking. I'm thinking about buying a rebuilt unit with a little bigger gears like the 3.55. Question, will I only notice a difference from a dead stop.. Will I notice any difference doing 40mph and punching it like when I'm passing someone? I now the engine will tach higher at faster speeds but is it worth doing? I haven't price out what it would cost to have the seal fix/replace but I'm guessing it's not TOO much more than buying a rebuilt.. Thoughts?
Old Jun 6, 2002 | 12:09 AM
tnt76vette's Avatar
tnt76vette
Default Re: Rear Gear Question (Koz)
3.08s are great on the Freeway, while 3.55s are great for cruzin'. My 3.55s turn 3K @ 70mph ( a bit much for chambered pipes!). I dont do much freeway drivin, but I dont think I'd be happy with 3.08s for cruizin either. You call on this one from my point of view....... :cheers: :cheers:
Old Jun 6, 2002 | 09:25 AM
Koz
Guest
Posts: n/a
Default Re: Rear Gear Question (tnt76vette)
Thanks for the reply. What I'm after is how the 3:55 will feel at higher speeds. I usually do between 45 and 55 on back roads to work.. Ocassionally on freeway but mostly the 45 to 55 range. I come across a lot of 40mph folks on these roads. Probabbly cause that's the speed limit..:lol: There is only a few places you can pass because the road is windy. I wanted to know if I"m doing 40mph or so and stomp to pass will I feel any more pull or faster pickup with 3:55 or will I be reaching peak HP :confused: because of the higher gears and loose any benefit of the bigger gears. I know from a stop the 3:55 will give me more feel in the seat of my pants.. wondering about upper end..
Old Jun 6, 2002 | 09:32 AM
Alwyn678's Avatar
Alwyn678
I would go with 3:73's if you do not do a lot of interstate traveling...Man what a difference it made in the way my car launches..It also goes like a Bat out of hell when you stomp on it at speed :cheers:
Old Jun 6, 2002 | 09:40 AM
Gordonm's Avatar
Gordonm
Default Re: Rear Gear Question (Alwyn678)
The 80 uses a different rear than the 63-79 cars. You actually have 3.07 gears. The ratios available to you are slightly different then the normal 63-79 cars. They are available for different ratios but make sure they are for an 80 and not 79 and earlier. Your car has the Dana rear in it.
To Rear Gear Question
