C3 Brakes
i have a 1975 t-top 3 speed auto. i have noticed the brakes dont work very well. they dont seem to be defective in any way but they just dont work nearly as well as the breaks in my 2000 cherokee (only other car i have ever owned)
i was told the breaks are fine and thats just the way they used to be. can anyone confirm? is there anything i can do on a budget to improve the performance of my brakes? any info people would be willing to share would be awesome.
thanks in advance,
Corey
You need to be a bit more specific than "my brakes don't work very well".
OK - Is the pedal long and goes toward the floor before braking begins?
Does the car pull to one side during braking?
It just takes a lot of pedal effort to get the car stopped?
I can't lock the brakes up even if I tried?
There are a lot of different things that can be less than perfect and effect your braking.
Refine your issue if you can.
RGDS
Bob
RGDS
Bob
the pedal does seem to be long i would say about 50-60 percent depressed before i get any breaking action.
the breaks do pull very slightly towards the passenger side but ive driven much worse.
it did seem to take a lot of pedal action to get the car stopped but this is the only corvette ive ever driven.
i couldnt get the breaks to lock if i tried. on a test drive down the street i slammed on the breaks with no nosedive at all, just a gradual stop.
really to recap, everything you mentioned are symptoms i am experiencing.
Corey, is there a power brake booster can between the master cylinder and the firewall?
Also, you may have air in the system. Sometimes if the car pulls to one side or the other it may mean that there is air in the system somewhere. You may want to bleed the brakes.
Keep in mind that the rear brakes on C3's have two bleed screws. It is possible that someone didn't bleed both and there is still air in the system.
In my 69 (with factory power brakes) I believe if I don't wear the seat belt I would fly be thrown through the windshield when I hit the brakes
The brakes can be a PITA to get working properly, but once you have the air out of the system, working cylinder and brake booster they are excellent.
If you don't have power brakes they also work just fine, you just have to step harder on the pedal
A well maintained stock brake setup will make you a happy driver.
With "well maintained" i mean:
Non leaking and fully funktioning calipers, master cylinder and servo.
A set of new pads (if your old pads ar 50% worn, change them out!).
Straight and non scratched discs
Fresh brakefluid.
Bleed out 100% of the air in the system
There is a few simple steps to make your brakes even better..
A set of HP street brake pads
Steel braided brake hoses
Something people often forget about is that one should change the brakefluid often.
I change my fluid once a year.
Reason for this is that the fluid gets warm from braking and cools down over and over again.
When this happens one get condense water in the fluid wich starts to boil very easy, and when this happens one looses the brakes.
Stepping on the pedal only result in that one compresses tha airbubbles created by the boiling water and the brakes are gone..
A good service is easy to do yourself.
//Ricky.
Fresh brakefluid.
//Ricky.
In fact I allways had to be carefull when jumping into my other cars after putting in multiple days of enjoying the Vette. You can really get spoiled with the stopping power on a C3.
