C3 Brakes
The C3s have fixed calipers that have pistons on both the inside and outside halves of them. This means that rotor runout is very important. If you have more than a few thousandths of an inch of runout in the rotors, the pistons pulse and suck air at the piston seals. There is some discussion on the piston seals themselves as well. The factory installed standard lip seals and they worked well for a long time. Then someone started putting O-ring seals in as a replacement, and there are folks who like that approach. As far as I can tell, they both work find. The calipers are typically fitted with stainless steel sleeves in the piston bores now to prevent corrosion and increase longevity. Finding calipers that aren't sleeved is becomming more and more rare. Any replacement calipers you buy will typically be sleeved. If you have the choice, choose the sleeved calipers when replacing yours if you have to. The calipers are in two pieces. There's a small o-ring that seals the passages from one side to the other, this is another area that can leak. If your calipers are leaking, they usually leak from the pistons first, then through the dust boots around the pistons, and then they can leak between halves. Overall though, once these are rebuilt correctly, they last for years and years, probably longer than you'll own the car!
The rotors on these cars are riveted in place. Why? Because of the runout issue described earlier. These rotors aren't like the consumable rotors out today. They didn't usually need replaced or even turned, just the glaze broken. Removing these from the hubs is a job. You have to remove the rivets, do what ever it is you're going to do, and reinstall them making sure your runout is less than .003. I think that's the right spec, it'd have to be verified.
Another area of concern on these cars is the rubber brake hoses on each corner. Those aren't usually replaced and they wear over the years.....from the inside out. You can't see the wear, and when they go bad they usually colapse causing no brake fluid pressure to that corner. If you rebuild your brakes system, check and replace these as necessary.
And then there's the master cylinder. It's a big capable piece that doesn't require any special attention with the exception that you MUST bench bleed a new/rebuilt unit before installation. This isn't unique to C3's but it has to be done. You can do it before you install it, our after you install it and remove it again, but you're gonna do it! The vacuum booster on these cars is a standard vacuum booster, nothing special here either.
Bleeding. The other unique beast on a C3 brake system. You bleed these systems using what ever method you like, gravity, pump and hold, power bleeder, or vacuum method. The key is to start at the rear, and bleed the inner caliper half on the side your working first. Then move to the outter half, bleeding each caliper completly before moving to the other side. I start on the passenger side of the car first, farthest from the master cylinder. The front calipers only have one bleeder so you bleed them like any other brake system.
So there you have it Corey. If your brake system is working properly, it'll stand the car on it's nose (not really, these things don't nose dive much!..
). The pedal pressure won't be as easy as the late model hydroboost systems (some have done hydroboost conversions to C3's though), because it's a vacuum assist, not hydraulic, but it'll work very very well.
). The pedal pressure won't be as easy as the late model hydroboost systems (some have done hydroboost conversions to C3's though), because it's a vacuum assist, not hydraulic, but it'll work very very well.OP - I have had the same issues you are experiencing and it took a lot of effort to bleed the brakes completely. I eventually got them bled all of the way by the gravity method. It was the first time I have ever done it that way on any car. I wasn't certain how well it would work but it turned out the most effective. My brakes on my 77 are better than either one of my 2000+ vehicles. Except ALB of course.
The rotors on my 74 smallblock have never been turned. They have 170,000 miles on them.
And if you jump on the brakes hard, your sunglasses could hit the windshield.......
If the rotors are in reasonably good shape and there are no fluid leaks onto the rotors/pads, then it is most likely that your braking power is limited by very poor quality brake pads. Causing the tires to lock-up should be no problem with brake system in decent condition, good quality pads, and stock tires. If you have very wide, grippy tires, that might be more difficult.
There are many good quality brake pads out there. The ones with the best stopping power are very abrasive and will create a lot of nasty brake pad dust that is filthy on your wheels and difficult to clean; most are metallic or semi-metallic pads. There are also some ceramic pads that don't provide quite the stopping power, but don't make the kind of black dust that metallics make. Go to NAPA and ask what your options are. Or, research the issue on the internet until you decide on a pad that meets your needs.
If you have air in the brake lines, the pedal will feel spongy and you will never build the kind of pressure needed to have crisp stopping action. And bleeding the C3 brake system is not a simple process. Use the SEARCH function on this Forum to read about how to bleed the brakes, if you have a 'spongy' pedal.
Lastly, if someone installed the wrong master cylinder on your car (in earlier times), your system may not be able to generate the fluid pressures that a stock car can produce. I'm not quite sure how you check that out, as different M/C's may use the same casting to make the housings. The difference is in the valve spool sizes, internally. Others may be able to advise you better on this one.
I'm thinking that the rod connecting the pedal to the m/c has been replaced with a shorter on sometime in the past.
Any of y'all been around this one before?
