Sluggish Headlight Mystery ........... Solved?
Old Jun 6, 2002 | 12:55 PM
LABulldog's Avatar
LABulldog
Default Sluggish Headlight Mystery ........... Solved?
I had wondered why my headlights took a couple of seconds to open. I just thought I had a vacuum leak (probably do anyway). Well, in starting to research the problem, I discovered that Bubba had removed the vacuum tank that should be under the front nose. Is there hope in finding a decent one at a junk yard or best to bite the bullet and buy new one?
Old Jun 6, 2002 | 01:00 PM
Neo Fender's Avatar
Neo Fender
Default Re: Sluggish Headlight Mystery ........... Solved? (LABulldog)
Isn't the vacuum tank like an integral part of the frame? :confused:
Old Jun 6, 2002 | 03:07 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Sluggish Headlight Mystery ........... Solved? (Neo Fender)
You don't need that tank, it's just there so when the car isn't running you'll be able to open the lights a couple times. I also thought it was a part of the frame, at least mine looks like it is...
:cheers:
Old Jun 6, 2002 | 03:22 PM
Alwyn678's Avatar
Alwyn678
Default Re: Sluggish Headlight Mystery ........... Solved? (Metal_Wulf)
I do not even have one......Lights work fine though........Car must be running of course
[Modified by Alwyn678, 2:23 PM 6/6/2002]
Old Jun 6, 2002 | 03:37 PM
LABulldog's Avatar
LABulldog
No, the tank (at least on the 80 model) is removable. I have a hoop type clamp that is attached to the support steel between the headlights under the nose piece. Needless to say the clamp is empty. I have seen replacement canisters in the various catalogs. You can usually find them under the section dealing with the headlights. In some catalogs it's not that easy to find them especially if there is no diagram or picture.
Old Jun 6, 2002 | 05:28 PM
tboltkc's Avatar
tboltkc
So, I take it from this conversation the lights aren't supposed to take a few seconds to come up? Hmmm. Just thought that's the way they worked. Vacuum leak the usual culprit I guess?
Old Jun 6, 2002 | 05:47 PM
Alwyn678's Avatar
Alwyn678
Default Re: Sluggish Headlight Mystery ........... Solved? (tboltkc)
Sounds that way to me
Old Jun 6, 2002 | 10:16 PM
Double_0_7's Avatar
Double_0_7
Default Re: Sluggish Headlight Mystery ........... Solved? (Alwyn678)
My lights don't work unless the engine is running either. I also assumed that this was the way correct ones worked. The guy I got my car from told me his name, but I bet if I checked his birth cert. his middle name would be bubba. You should see some of this guy's wiring.
Mine also open one at a time. Could this vacuum tank be why that is as well?
[Modified by Double_0_7, 2:17 AM 6/7/2002]
Old Jun 7, 2002 | 12:33 AM
Sean Willard's Avatar
Sean Willard
Default Re: Sluggish Headlight Mystery ........... Solved? (Double_0_7)
Mine used to open one at a time and also took about 3-4 seconds to go up and down. I thought it was normal also until I saw my buddy Viril's 79' I bought a complete new set of vacuum from Zip and I also got the actuator rebuild kits. It was kind of a PITA to get the actuators out but if you patient with them you'll get them. The whole thing cost only about $80 and my lights work great now. They go up and down together and in less than a second. I can also get them to move with the motor off. You might want to get a vacuum gauge and try to locate the problem first, I know the vacuum relays are prone to going out.
It's nice to have proper working lights and it's a pretty cheap and relatively easy fix. Good luck!
[Modified by Sean Willard, 11:36 PM 6/6/2002]
Old Jun 7, 2002 | 12:41 AM
Jason628's Avatar
Jason628
Greetings,
Yeah those actuator rebuild kits are nice..cheap and easy to do...Highly recommended! The good thing is that from my experience all but 3 were totally fixed just by doing that!
To Sluggish Headlight Mystery ........... Solved?
