electric choke
Old Nov 3, 2012 | 06:28 AM
buckhorn 76's Avatar
buckhorn 76
Default electric choke
i will be rebuilding my m4mc q-jet in the spring. the carb works surprisingly well now but the car sat in storage for 17 years. i have access to a bench top ultra sonic unit so clean up will be a snap,these things do an amazing job. i will do a conversion to electric choke as well. can anyone recommend a good kit? i am thinking that the best way to power it would be with a relay through the alternator. but i was also wondering if it is possible to go through the oil pressure switch? the car is a 76 stock l48 . thanks.
Old Nov 3, 2012 | 10:02 AM
oldalaskaman's Avatar
oldalaskaman
it needs to be 'switched' hot, not constant, you dont need a relay, and make sure its a choke specifically designated for that carb.
Old Nov 3, 2012 | 10:19 AM
thegazman's Avatar
thegazman
Default thegazman
Some of the people I know used a switched wire off of the wiper motor.
Old Nov 3, 2012 | 10:24 AM
'75's Avatar
'75
http://www.summitracing.com/parts/jet-201355
To electric choke
