Driveshaft Removal
Old Nov 3, 2012 | 05:38 PM
Last Special's Avatar
Last Special
Default Driveshaft Removal
How can I remove the driveshaft of my 1980 C3 when the rear bolts at the differential yoke can barely be seen? it's sitting on the rear wheels. I suppose I have to remove the half shafts so I can turn the driveshaft to remove the rear bolts. The transmission has been removed. Any suggestions?
Old Nov 3, 2012 | 06:25 PM
diehrd's Avatar
diehrd
You have to use a 1/4 inch ratchet and extension at least thats how I did it on mine this past week , also the bolts are 12 point which makes getting a socket on them easy. And it is a lot easier if ya just set her on jack stands .
Old Nov 3, 2012 | 06:28 PM
scottw's Avatar
scottw
You can jack up the rear of the car and turn the driveshaft by your hand. Just make sure you mark the driveshaft to make sure you put it in the same way and not 180 degrees off.
I used a socket and wrench with a 6 and 3 in extender to get at the bolts. Supper easy with the tranny already out.
Old Nov 3, 2012 | 07:41 PM
Last Special
My problem is that the car is jacked up on its wheels, so I can't turn the driveshaft to get at the bolts. That's why I asked about disengaging the halfshafts, at one end. Does this help explain my situation any better?
Old Nov 3, 2012 | 08:05 PM
7T1vette's Avatar
7T1vette
So, jack it up under the rear shock mounts or trailing arm. That will raise the wheels and keep them level.
Old Nov 3, 2012 | 08:40 PM
Last Special
Default Halfshaft Removal
Thanks to everybody. I'll work it out from here.
Old Nov 4, 2012 | 09:55 AM
jnb5101's Avatar
jnb5101
you'll have the same problem removing the halfshafts as you have with the driveshaft. the only way to access the bolts is to rotate the ujoints by rotating the wheels.
Old Nov 4, 2012 | 10:43 AM
Last Special
I'm not arguing with you, but I'm confused now. Are you saying that I can't disengage the inboard U-joint of each halfshaft (so I can rotate the differential to remove the propeller shaft) without rotating the wheels? Are you also saying that I can't disengage the outboard halfshaft U-joints without turning the wheels? Thanks for your clarification.
Old Nov 4, 2012 | 01:34 PM
7T1vette's Avatar
7T1vette
He's saying that you have the same "issue" with half-shafts that you do with the driveshaft. You have to raise the rear wheels so that you can turn them to gain access to the bolts. And this has to be done while not allowing the wheels/half-shafts to droop and not be able to turn freely.
Old Nov 4, 2012 | 02:29 PM
'75's Avatar
'75
You can't disconnect the half shafts because they are the upper link in the rear suspension and the weight of the car is forcing them in toward the diff, even if you can get to the bolts. To turn the drive shaft you will have to raise the rear wheels, if the posi is weak, you may get away with raising one wheel.
Old Nov 4, 2012 | 04:42 PM
7T1vette's Avatar
7T1vette
The GM Service Manual indicates that you should use the strut-rod adjustment to provide more space for half-shaft removal.
Old Nov 4, 2012 | 04:45 PM
'75's Avatar
'75
The op stated the car is sitting on the rear tires, did I miss something?
Old Nov 4, 2012 | 05:37 PM
Last Special
Yes it is jacked up high and set on blocks. I can't jack it up any higher or it will be unstable and unsafe. I have to figure out a way to rotate the halfshafts without having to rotate the tires.
Old Nov 5, 2012 | 12:26 AM
7T1vette's Avatar
7T1vette
Maybe it would be easier to lower the car on the tires, THEN jack it back up under the shock mount or the T/A bearing housing.
Old Nov 5, 2012 | 07:33 AM
Street Rat's Avatar
Street Rat
You may be able to remove the driveshaft without rotating the yoke but of course it would be far easier. It sounds like you have it up in the air enough to get under it. I lay with my feet facing the rear of the car. Look down the driveshaft towards the differential. You can see the four attaching bolts. I then use a very long extension on a 1/4" ratchet. On the end is a 12 point 1/4" socket. You can put a small amount of grease or a piece of paper towel inside the socket. This will keep the bolts from falling out after unscrewing them. Then CAREFULLY move the bolt and tools toward the front of the car down the driveshaft. I've done this before and it works. Good luck my friend!
Old Nov 5, 2012 | 09:21 AM
Last Special
Street Rat, thanks for your suggestion. I will try it. For additional information, would you know if I could disengage the inboard (or outboard ) halfshaft U-joints so I could rotate the propeller (drive) shaft and the differential? It would be good to have that option.
Old Nov 5, 2012 | 09:27 AM
Street Rat's Avatar
Street Rat
To Driveshaft Removal
