Shock Mount Question
Old Nov 3, 2012 | 08:02 PM
76Vett's Avatar
76Vett
Default Shock Mount Question
Should the shock mounts on boths sides fit flush against the Trailing Arm Spindle Support bracket. I've got my new ones and they have those ridges that prevent it from pulling up flush.
Old Nov 3, 2012 | 09:59 PM
Mooser's Avatar
Mooser
Yes
The ridges (splines) are there to dig into the bracket and help prevent it from turning (along with the "D" shape at the threaded end
Bring the nut to the proper torque and it should pull the spline in fully
Mooser
Old Nov 5, 2012 | 11:54 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
You should not draw in the splines and torque the nuts down on the mounts until the weight of the car is on them and the rear suspension has settled on the proper ride height. Otherwise the shafts will not be perpendicular to the centerline of the shock absorber...causing the rubber bushing to fail prematurely.
Old Nov 5, 2012 | 12:00 PM
Mooser's Avatar
Mooser
Good catch, forgot to mention that. Same with most of the rest of the rear suspension. Check the manual(s) for specifics
Mooser
To Shock Mount Question
