Im troubleshooting the AC in my 78.
Everything seems to work, but the compressor wont turn on.
I bypassed the low pressure switch, but still nothing.
There is power at the green wire on the low pressure switch.
There is power at the Fast Idle solenoid.
Is the compressor just bad?
I have not just put power directly to the compressor.....
Below that, at the (high pressure?) switch, there is no power. It has a blue and a Dk Green wire.
I cant find these wires on a schematic to see where they terminate.
this is a wiring sch. for a 78 the (highpress switch) is probably the thermostatic switch. will need to jump it out to see if comp. will engage. make sure the ground wire off the plug is in place for the compressor also. http://www.corvetteforum.net/c3/tune.../index16.shtml
