More Power Scotty!!!
:confused: :confused: :cheers: :chevy
Scott
[Modified by Scott78, 7:02 PM 6/6/2002]
I mean no disrespect with my following statement; you've got a numbers matching base engine Vette, not an LT1 or big block. I, repeat, I wouldn't be as concerned about matching numbers on a 350/300 as I would be on an LT1. With that said, here's my suggestion:
Rebuild the shortblock with quality but not exotic parts. Pay the extra for professional balancing & maybe even blueprinting. As part of the rebuild, install a new hi-perf cam to match your chosen compression ratio. Because you probably don't want a high reving race engine, you can keep the compression ratio within a very practical range. FYI, the base 350 cam is THE limiting factor in your current setup, bow-wow.
Next, instead of rebuilding your decent heads, buy a set of new-tech high performance heads. Aluminum would be a great choice if you can afford it. Factor your head material choice in your final compression ratio decisions. Store the original heads.
How's that sound?
If you got more questions, try this site for specific cam, head, & general recommendations: http://www.1-4u-computer-graphics.co...cgi?board=perf
Nunus79- No disrespect taken- I agree with you.
-Rottenrob
:cheers: :cheers: :) :) :chevy
