82' Crossfire Corvette Carb Conversion
Old Nov 8, 2012 | 04:04 PM
AngusClyde's Avatar
AngusClyde
Default 82' Crossfire Corvette Carb Conversion
What parts do I need to make the conversion from my Crossfire Injection to Carburetor?
Any help would be appreciated. Thanks.
Old Nov 8, 2012 | 08:11 PM
alexns's Avatar
alexns
Suggestion: Find a tpi setup. 91-92 camaro firebird. Get one with ecm and harness. Way more bang for the buck. Fits nice even with the v belt setup. Just need to change your fuel pump to one from a tpi car.
Done the carb swaps before. Efi waayyy better.
Old Nov 8, 2012 | 10:44 PM
Crepitus's Avatar
Crepitus
A carb? Sorry couldn't help it. To just drive it you will need a carb(!) intake, distributor and a fuel pressure regulator. To go fast you will need heads n a cam to. There was a thread just a couple days ago here that you might want to dig up.
Old Nov 8, 2012 | 10:53 PM
oldalaskaman's Avatar
oldalaskaman
http://forums.corvetteforum.com/c3-t...crossfire+carb.
Old Nov 10, 2012 | 02:49 PM
AngusClyde's Avatar
AngusClyde
Thanks for the link.
Old Nov 10, 2012 | 03:26 PM
oldalaskaman
Its been done a lot, successfully. hope it helps, this site and others have lots of info, also check C4, good info there also.
Old Nov 10, 2012 | 04:26 PM
7T1vette's Avatar
7T1vette
Why even buy a CrossFire C3, if you don't want the TBI's and ECU????
Old Nov 15, 2012 | 12:15 PM
wilcar's Avatar
wilcar
I did a carb conversion on my 84 crossfire, much better performance even with the stock cam and heads. I did a post on this site, not sure if the gremlins deleted it or not but if you have questions you can email me at docwilcar@yahoo.com if you need help as the C-3 and C-4 conversion would be almost the same. I used a 600 cfm Edel. carb(500 cfm good to 5000), ZZ4 intake, accel hei dist., mallory 4309 fuel pressure reg. I later added a set of Summit/Dart SS cast iron large valve heads and an Isky Z-20 solid lifter 228-228, .450 lift, 108 LSA cam. I am still using the stock stainless steel headers(you probably have the same) and a true dual exhaust system with no cats. The car is pretty quick compared to the stock crossfire!! Good luck!
Old Nov 15, 2012 | 01:34 PM
Crepitus's Avatar
Crepitus
good to hear from you! I like the cam choice, How did you like the results of the head cam swap? How much vacume does it pull?
Thanx
Dave
Old Nov 15, 2012 | 01:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why not tune the crossfire and keep the rest of the money in your pocket?
Old Nov 15, 2012 | 08:02 PM
wilcar's Avatar
wilcar
Hey Dave, the Summit heads made a big seat of the pants feeling for sure, no dyno or strip numbers but for $630 they are a bargain. I replaced my 274H06 218-218 106 lsa cam with the Isky z-20 which has been around since day one, 228-228 .450 lift, 108 LSA. It idles better than the 274 cam and is a mild cam like the 097 Duntov. I am pulling around 16" of vac at 900 and 14.5 at 700 where it idles fairly smooth, hardly a lope. It seems to have better low and mid range than the 274 cam and I love the solid lifter sound . I ran the 097 cam in my 327 in my 57 Chevy back in the day and I have always been a big Isky fan. The Z-20 was designed to have similar specs as the 097 but with more lift. I had Isky grind the Z-20 on a 108 LSA as the current version is on a 112 LSA. Really nice cam if you are into old school cams that are easy on your valve train and work with stock spring(my summit heads have the .525 Z-28 style springs). I have the same spec cam in my 1965 455 GT0 with dual fours, 4 speed and 3.31 gears.
Old Nov 16, 2012 | 02:39 AM
Crepitus's Avatar
Crepitus
thanks
To 82' Crossfire Corvette Carb Conversion
