L-82 hp
Old Nov 10, 2012 | 09:00 PM
brady5885's Avatar
brady5885
Default L-82 hp
Roughly what HP would a '76 L-82 have with Edlebrock intake, holley carb, blue racer cam and roller rockers.
I know it's kinda vague but that's all I have on it.
Old Nov 10, 2012 | 10:08 PM
Vette5.5's Avatar
Vette5.5
Really not seeing anything you mentioned except the camshft doing much, and really not sure of the specs on that. I'd start with what you've already got, probably going with a cat free dual exuast, rejetting the existing Q-Jet carb, and go over the the distributor. Then see what you've got. Either way, I'd stay with the Q-Jet, throughout a build up.
Old Nov 11, 2012 | 12:10 AM
drwet's Avatar
drwet
L-82 already had an excellent cam. That would not be the first thing I would change if I was looking for more power.
Old Nov 11, 2012 | 06:34 AM
jb78L-82's Avatar
jb78L-82
Below are the video of my 78 L-82 4 speed on the dyno as well as the dyno sheet:
Engine is stock L-82 internals (66,000 miles) with:
McJacks Shorty headers
2.5 duals with Monza Turbo mufflers
Holley 4175 650 CFM Qjet with Softest secondary vacuum spring
Com Cams 1.5 roller tipped rockers
Stock Dual Snorkel L-82 intake housing and Stock L-82 Aluminum intake
Stock 882 heads
Stock L-82 cam
Dyno Sheet: 233 RWHP, NOT Net HP, Not Gross HP which would be MUCH higher than RWHP. 269 Rear Wheel Torque!
Old Nov 11, 2012 | 06:54 AM
71454Chevelle's Avatar
71454Chevelle
Without more details on the new components, there is no way to know.
Old Nov 11, 2012 | 12:40 PM
brady5885's Avatar
brady5885
It's not what I'm puttin in the car, it already has the components, I was curios as to what HP it may have.
What's the best thing for the money to gain HP?
I will put hooker side pipes on also
Old Nov 11, 2012 | 08:28 PM
7t9l82's Avatar
7t9l82
what in the world is a "blue racer" cam?
Old Nov 11, 2012 | 08:42 PM
PeteZO6's Avatar
PeteZO6
Crane Cams has or had a line of cams they named Blue Racer. From the table listing the SBC cams, they look to be mostly "old school" i.e., easy ramps, and moderate lift economy cams. For instance, their CD214-11 grind appears to be a close clone of an L79 327/350 cam. LINK
Knowing the OP has a Blue Racer doesn't really tell us anything other than the brand name.
Pete
Old Nov 11, 2012 | 10:52 PM
drwet's Avatar
drwet
Making power is about matched components. Without knowing what cam you have, its hard to make recommendations (but I'll try anyway ). In my experience, the best bang for the buck is usually headers and a free flowing exhaust system.
Old Nov 11, 2012 | 11:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Pete
Right. There are probably 20 different "Blue Racer " grinds from mild to wild.
Old Nov 12, 2012 | 02:02 AM
Korevette's Avatar
Korevette
Pick a target and aim for it.
The old game of 'just add this and then that' likely leads to a world of disappointment. If you are chasing a dream of horsepower which I fully endorse on a 1976 L-82 with the additions you have mentioned will only bring you to the next basic level. 30 horsepower gain ? maybe...
Anything after that I would highly recommend a motor pull. Seal and secure the L-82 for the 'next' buyer and then put in the new 'dream bullet'.
Old Nov 12, 2012 | 07:24 AM
Matt Gruber's Avatar
Matt Gruber
look on the end of the blue racer box for a part #
Old Nov 12, 2012 | 08:51 AM
lars's Avatar
lars
Here's my guess:
Stock '76 L-82 was 210 hp.
The Edelbrock intake won't gain you anything over the stock L-82 intake on a near-stock engine, so no gain there.
The Holley carb will probably drop you about 10 horsepower from the stock Q-Jet, so that puts you down to 200.
The cam, if it's a mild upgrade from stock, could add 10 hp.
The roller rockers only help to reduce side-loads on the valve stems, and won't add any more power.
This puts you right at the stock 210 hp level, with a probable loss of low- and mid-range torque from the square-bore carb.
Lars
To L-82 hp
