So instead of the metal of the axle rubbing on the inner sleeve, your just rubbing your poly over the inner sleever. Wonder how long that is going to last.
No, he's saying that there are poly bushings available that have inner sleeves with serrated ENDS, similar to the OE rubber bushings. The serrations "lock on" to the flat washers that are installed to retain the bushings, and the bolts, in turn, lock up against the washers.
From: Graceland in a Not Correctly Restored Stingray
Sorry, imo incorrect. If the sleeves are serrated they are connected to the shaft via the bolt. Therefor the bushing has to turn over the inner sleeve.
I studied the poly question thoroughly and came to the conclusion that they have no place on our car. I threw the out before the body is mated again to the frame. All rubber now.
I used to work for the Department of Energy on defense projects. Polyurethane does indeed have a life expectancy some of it as low as 10-15 years. I would tend to agree that the OEM rubber bushings are pretty decent pieces although some of the currently available parts made overseas aren't up to OEM standards.
Actually the rubber bonding the inner/outer sleeves together twists in motion between the 2 sleeves in an OEM bushing. That is the reason why you should only do final torquing of control arm bushings when the car is resting at finished ride height. If you torque the bushings at full suspension drop you will prematurely wear them out through excessive twisting of the rubber.
I was replying on the polys. Rubbers work differently.
81pilot...
It is good to know that your are the "one and only" purveyor of TRUTH! I've been looking for "the omnipotent ONE" for many years; I can finally relax and know that you have all the answers and that I should no longer be concerned about the ramblings of anyone else.
But, contrary to your misguided belief, there are MANY synthetic rubber compounds [to my knowledge, NO ONE sells a 100% rubber product for anything these days] that can last and function well for 20 years OR MUCH MORE. Now, whether you can find a good quality product or not is an entirely different issue. But, many C3's which have been used in the 'more friendly' environments in the US have body mounts that survived 20-30 years with no real functional problem. They might have been ugly and somewhat cracked on the outside, but they worked just fine.
Many military applications require materials that see much more difficult service and environments and, by contract, must be servicible for more than 20 years.
Would I recommend to anyone on this Forum that a good quality body mount would last 20 years? Sure....because I'll be dead before that 20 years is up!!
P.S. If its a polymer or synthetic rubber product made in China...it's doubtful that it will last even a reasonable period of time. There is even significant risk that it's not even made out of the material claimed.
I would rather be called a perveyor of truth than the biggest Narcissistic Ahole on a forum, you got that one all sewn up. So what you are saying is that your "truth" is better than my "truth",,,,I leave up to people and give others credit to discern the actual truth. Rubber dries out.....fact...losing its original specs, true or false? If true, which it is, then the fact is is there with a few cracks only validates my point. Why don't you move away from the mirror and quit strokin your ego long enough to realize others don't live in your world, what a moron you can be. I apologize for others for strolling into your world of name calling, but you bring it out in me.
