I have an '82 Vette that I hardly drive anymore. I've probably put 8,000 miles on the car in 10 years I've owned it, and probably less then 100 in the past 3 years. The car spends all of its time in the garage
Well, today I pulled it out and put it up on the rack to get some minor issues I've been neglecting fixed. I was shocked to see that ALL of the poly in the car was rotting away. Not just cracking, but some of it was completely gone! Sway bar cushions, dual mount spring "cushions", spring bolt cushions, etc. The only thing that appeared to be in decent shape was the poly body mounts. I'm not exaggerating when I say that all 4 of my front and rear dual mount spring bolts had at least one cushion that had completely rotted away.
I have a '72 also that I just had to replace all four of my rear dual mount spring mount cushions in for the same reason, but the rest of the poly looks in that car looks OK. That kit has been in there for less then 6 years. I'm just wondering if anyone else has had a similar issue or might know what is causing this.
I've had poly bushings in my car for 15 years, and put maybe 20,000 miles on it in that time. They squeak a little, but otherwise they look like the day I put them in. Got them from Vette Brakes.
My "guess" is that you've been lubricating those poly mounts with something that they don't "like". If so, share that info with the Forum, so that others don't have the same problem. In general, plastics should not have petroleum products put on them...plastic is made out of petroleum substances, and over time they will break down.
But, I wouldn't think a 'good' poly bushing would break down that quickly, even with a 'toxic' substance. Have you contacted the vendor about this problem? They may have info...or even be willing to supply you with 'good' replacements if there was some problem with them.
I studied the poly question thoroughly and came to the conclusion that they have no place on our car. I threw the out before the body is mated again to the frame. All rubber now.
Sorry to disagree but after 30 years of using poly bushings on my C3 I have concluded based on my real world experience that poly bushings can be a tremendous addition to the suspension of C3's as long as one can deal with an occasional squeak from them AND in 2 locations I would not recommend them:
1. Struts rods-Heim joints are the way to go in that location
Other than having a life span of only 20+ years and offering a bit more 'give' in the motion of body/suspension members [exactly what they are supposed to do], what are the downsides to using rubber bushings/cushions like were installed at the factory?
If those are the only 'limitations', that makes a pretty good case for using rubber, rather than going to poly material.....except in the case of someone who might be using his/her C3 for road racing.
I don't use anything to lubricate the poly on the car. I'm wondering if it is something in my garage causing the rapid deterioration. I don't store any chemicals other then car care products and they are all on shelves of course. The only other thing I can think of is maybe some of the chemicals from washer or dryer in the air
Just wondering if anyone else has experienced this.
I had the same issue as SuperJames. The front end control arm busing fell apart. Got them from Corrvette Central. Less then 3 year on the 1978 SA garage queen. I attribute the failure to over tighting, as they kept on coming loose.
This year, I changed all control arm bushings to rubber. They have not come loose or needed any re-tighting.
2. Trailing arms bushings.
Hope that helps!
There are numerous other threads about poly's desintegrating. I know of a big one on another forum.
As for poly's on the front trailing arms : you're probably well aware that poly is a sticky sort of plastic. If you replace the bushing with poly the arm axle has to turn on the bushing. It will smear the poly, which is why it starts to make noise and all sorts of other things. There is more : the axles on which the A-arms turn are not straight. (try rotating one on a lathe and tell me why). Which causes additional force in a point in the poly bushing. This will destroy it in due time.
As for the bushings in the other locations : as soon as there is rotation involved they will cause problems.
Then there are the trailing arms : these do not only rotate on the bolt, but the also twist.
There are 'good' polymer materials that would have no problem lasting many, many years without problem. But, that would mean the vendors and manufacturers would have to make them out of something better than recycled plastic grocery bags! Since a black plastic trash bag will stay intact for more than 1000 years...buried in a landfill, there's NO reason that a poly bushing in a C3 should fail. Corvette Central just sent you 'dirt-cheap' plastic parts--and smiled all the way to the bank.
Call them and complain, loudly. Nothing changes until disgruntled customers make themselves heard.
From: Graceland in a Not Correctly Restored Stingray
Poly is one of those gray area products, attempting to span the broad gap between stock and full racing kit, and tho it reduces unwanted compliance it does have some drawbacks. That said, my having had poly CA and bar bushings without significant issue for some 30 years, I'd put this down to poor material and/or unfortunate chemical reaction (most likely due to the former).
Regardless, I wouldn't recommend poly in the rear camber struts or TA's, both of which inherently move in 3 dimensions during suspension travel. IMCO one should either stick with rubber in such locations, or if all that serious opt for heim-jointed struts, and sphericals or Johnny Joints for the TA's. For my own purposes I plan on taking care of that last item while my rear suspension is apart for further mods, and I also plan to move away from poly in the front end when all is eventually said and done.
If all of this comes off as if I have a mixed opinion on poly, that would be a resounding "maybe". In any event, those who choose to put it to use should do so with eyes open, and bearing in mind that squeaking poly is always a sign of binding poly. It simply must be lubed periodically, and with the right type of goop, to avoid stiction. My ~$.02
Are you going back to rubber or installing steel? What about for the rear..rubber or steel?
I tried putting steel bushings in my trailing arms. The bushings would even go in. After a lot of thinking I put the axle in a lathe and sure enough the wobble was bad enough to take up all the clearance.
I then took another one, with the same result...
If you use poly, it has a little more give than steel, but not much more. That crooked tension originating from the axle has to go somewhere. Guess where ...
Your choice.
What "axles" are you referring to?
And FWIW, I've used poly bushings (exclusively Energy Suspension parts) off and on since the late 70s, and NEVER had one deterioriate.
It's certainly not for everyone, but my eventual aim is to eliminate compliance from all points which affect dynamic suspension geometry. To that end, tho I was against the idea a few years ago I'm leaning more and more towards converting over to delrin where suitable when I get back to the front. I haven't fully decided yet between sphericals or Johnny Joints for the TA's.
