Performer intake
Old Nov 15, 2012 | 08:48 AM
Tjf2000's Avatar
Tjf2000
Default Performer intake
Does anyone know if a performer rpm will fit under a stock 76 hood. I know the edelbrock catalog says no but I remember reading here that some people say it fits.
Thanks in advance
Old Nov 15, 2012 | 09:46 AM
scrappy76's Avatar
scrappy76
I had one on my small block that fit under the hood. I had one of those triangle shaped air cleaners with a flat base. It fit fine.
Old Nov 15, 2012 | 10:28 AM
LannyL81's Avatar
LannyL81
I have one on my '81 with stock hood and stock air filter with Edelbrock Performer RPM aluminun heads....no problems.
Old Nov 15, 2012 | 04:22 PM
Tjf2000's Avatar
Tjf2000
Old Nov 16, 2012 | 12:40 AM
glen242's Avatar
glen242
I have a '76 with stock hood, I believe the '81 hood height is the same, and no way will the stock air cleaner fit, using the Performer RPM intake. Mine works by using a drop base open element air cleaner, which I hate. Working to change that.
BTW LannyL81 in rereading your post it is not clear to me weather you have a Performer RPM INTAKE or just RPM heads. If you do indeed have a RPM intake under the stock hood using the stock air cleaner, please post a picture and/or description on how you did it.
Old Nov 16, 2012 | 08:22 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I have one on my 80 and it looks all original everything fits like a glove
Old Nov 16, 2012 | 06:09 PM
69small block's Avatar
69small block
Default intake
I am, using performer 2101 Qjet and drop base K&n filter set up it fits fine
Old Nov 16, 2012 | 06:42 PM
johnt365's Avatar
johnt365
The Performer RPM #7101 is .70 taller than the 2101
Old Nov 16, 2012 | 06:56 PM
Chappie's Avatar
Chappie
On our '79 I have a 2102 Performer with an Edelbrock 600CFM carb, but it needed a drop base for the air cleaner. I've got the matching cam and roller rockers too. Runs great with the Bow-Tie Overdrives transmission.
Chappie
Old Nov 16, 2012 | 07:33 PM
Tjf2000's Avatar
Tjf2000
Thanks again for all the help
Old Nov 17, 2012 | 06:46 AM
Sideways73's Avatar
Sideways73
What about a Performer Air Gap?? anyone running one of these?
Old Nov 17, 2012 | 10:25 AM
drwet's Avatar
drwet
I have one on my '79. I have an L-88 hood as it will not fit with the stock hood on my car. I also have a Moroso 3" air cleaner and 1/2" of insulation under the Holley carb, so there's lots of room with this set up.
Old Nov 17, 2012 | 11:37 AM
joerob727's Avatar
joerob727
If you look on Edelbrocks site, it lists the height of each manifold under each intakes 'technical notes'.
According to Edelbrock, the difference between the Performer and Performer Air Gap is .27 inches. About a quarter of an inch. So if you have a bit over a quarter of an inch on your Performer, you can go Air Gap.
Incidently, the RPM and RPM Air Gap are the exact same height.
Old Nov 17, 2012 | 01:52 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
A performer RPM works fine on my '78 with a drop base air cleaner having a 1 1/8" drop and a 14 x 3" air filter, but just barely.
Of important note, I've measured drop bases from less than an inch (won't fit) to as much as 2" such as the SHP air cleaner used on '65-'67 small blocks. As far as carburetors go, I measured the height of the 4150 and 4160 Holleys and the Quadrajets - they're the same.
To Performer intake
