Please help
Old Nov 15, 2012 | 09:59 AM
littleredvettegirl's Avatar
littleredvettegirl
Default Please help
I just purchased my dream car, a 1982 corvette c3. I drove it home and it ran just fine except it had no headlights and needs a water pump. When I got it home my "mechanic" (we'll just call him that because I want to be nice) touched a wire that was just hanging off of my started to another mystery thick black wire and it sparked, now the car won't start at all. I have panel lights and the radio comes on, I can even hear the fan but it won't even try to turn over. My question is a two parter, first what did he do? Is it an easy fix? and second what do i need to do to fix that and what do I need to do to fix my headlights. It has a 383 stroker, automatic, some electrical issues but was running just fine before those wires were touched. Please someone just tell me what to do and I will take care of my baby girl myself. I can send pics if that helps. All I want to do is drive her.
Old Nov 15, 2012 | 10:17 AM
SuperBuickGuy's Avatar
SuperBuickGuy
free "mechanic" are never free; they always cost LOTS of money to fix their "fixes".... here's it's called being Bubba'd
The wire - I'd guess that he grounded out one of the two power wires and blew the in-line fuse.... it's molded into the wire so it's not an easy fix, but it's also not terribly hard - just time consuming and requires some contortion techniques. That said, it may also be some kind of alarm system.... in short, more info needed
Headlights - find your local Corvette club (look at the bottom of the Forum page for people in your area, and clubs) and ask them. But your question requires more for us to even guess - do the lights go up? if they don't come on - check your high/low beam switch. If they don't come up.... uggg... anyway, specifically, what isn't it doing?
What is the water pump doing/not doing?
Old Nov 15, 2012 | 10:25 AM
littleredvettegirl
Thanks for the reply, first of all he's wasn't free he's rebuilding my 1965 chevy impala but he will never touch my vette again.
I will check the inline fuse, I just need to locate it
The headlights come up no problem, when I turn on the headlights it shows that my brights are on but no light at all and the bright indicator does not go off when I use the bright/dim switch. The guy I bought the car from stated that the radio wasn't working the day before but the lights were. He changed the fuse for the radio and now that works but I would rather have lights lol.
The water pump is straight up leaking and I am going out today to change it myself.
Is there anyway you can give me a hint on where the inline fuse is so I am not wasteing time looking.
Old Nov 15, 2012 | 10:26 AM
LannyL81's Avatar
LannyL81
Most likely the spark blew-out a fuseable link to the starter. Easy to replace, as long as you can get under the car as the fuseable link is at the starter....passenger side of the engine.
If there are loose wires in the engine compartment...these will all need to be addressed. There are wiring diagrams available online for free that you should get and use this to fix the wiring.
The L82 engine is a challenege at times to get running properly. It is a two year only engine, so parts are somewhat difficult to find with regards to the throttle bodies; internal engine parts are no problems.
Good luck and be sure to ask the Forum for help...that is what we all like to do.
Old Nov 15, 2012 | 10:33 AM
littleredvettegirl
what wire is it located in or is it on the starter, sorry my first vette anything from 1970 and earlier I know but past that I feel stupid.
Old Nov 15, 2012 | 10:44 AM
74modified's Avatar
74modified
If it does have a 383 swapped in, it probably does not have the original crossfire injection. Then it will not have the original ignition system. You probably will need someone (who knows what they are doing) to physically look at it to see how everything is hooked up. It is really hard to trouble shoot a modified car, without seeing or knowing the modifications.
Old Nov 15, 2012 | 10:52 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Good advice right there man!
Old Nov 15, 2012 | 11:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by littleredvettegirl
...what wire is it located in or is it on the starter...
The fusable link is part of the starter wiring harness. The generic auto fix it books (Chilton, Haynes, etc) will show them.
Unsolicited Free Advice: purchase the assembly instruction manual (AIM) and GM chassis service manual for your 82. Order a reproduction owner's manual if you do not have an original.
Headlight operation is two part. Opening and closing the headlight doors is 100% vacuum. Lights on and off is 100% electrical.
Old Nov 15, 2012 | 11:32 AM
littleredvettegirl
I have a couple of pics of the starter but I can't figure out how to post them with my message if someone can email me then I can send the pics maybe that would help. hissickpuppy AT yahoo.com
Old Nov 15, 2012 | 11:33 AM
Mike Ward's Avatar
Mike Ward
Pretty much like any GM vehicle going back to the '50s.
Old Nov 15, 2012 | 11:46 AM
scrappy76's Avatar
scrappy76
Since the headlights worked one day and the radio didnt, then the following day the radio worked and the headlights didnt, I would check
" ALL " the fuses under the dash. With having a engine swap, who knows what wires are still original. where was the wire at that your mechanic touched ? I assume it was not hooked up to anything ?
Pics are worth a thousands words. Plus guys work betta with pics
Old Nov 15, 2012 | 11:51 AM
littleredvettegirl
Like i said i can't figure out how to post pics here please email me and i will send them they show the wires touched. I did check all the fuses for the lights and they are all good.
Old Nov 15, 2012 | 12:50 PM
roadblock69's Avatar
roadblock69
This may sound a little over simplified but, check the headlight bulbs. I have had a similar situation to what you have and it ended up being two bulbs and a crossed filiment.
As far as a fusible link, I have never seen one of them fail with a short spark. They are a special wire designed to fail just before the harness turns to crap, but not that much before. I would rather think that the previous owner likely installed a remote fuse in the harness someplace. Good luck, I am sure that you will enjoy the car after you work out the bugs.
Old Nov 15, 2012 | 12:57 PM
littleredvettegirl
Lol I will check the bulbs, thanks.
Old Nov 15, 2012 | 01:35 PM
MIKE80's Avatar
MIKE80
If you look at my picture, right next to the exhaust header are the starter wires hanging after I removed my starter. The fusible link for the starter is the wire that has the white plastic fuse on it. Mine is an 80' but I'm guessing it should be the same as your 82' unless it was changed by a previous owner.
Also, unplug one of your headlight bulbs, turn on your headlights, and using a volt meter, check to see if you have voltage at the bulb socket, lite green and tan should be hot (high/low beams), black should be ground. Make sure the ground is good also.
Old Nov 15, 2012 | 01:40 PM
littleredvettegirl
wow thanks that was helpfull as soon as I get off work I will check thank you soooooo much. It doesn't look exactly like that but gives me a good idea where to look.
Old Nov 15, 2012 | 01:59 PM
MIKE80's Avatar
MIKE80
No problem. I just emailed you a copy of the wiring diagram I have for my 80'. Hope it helps.
Old Nov 16, 2012 | 07:07 AM
MIKE80's Avatar
MIKE80
I came across this post.
http://forums.corvetteforum.com/c3-t...ring-help.html
Old Nov 16, 2012 | 11:48 AM
Mashman's Avatar
Mashman
1) Create a free photobucket account.
2) Upload your pictures to the photobucket account.
3) Click on a picture you uploaded, and look for where it says "IMG code". Click there, and it will say 'copied'. This has copied the "IMG code" to your 'clipboard'.
4) In your post on CF, simply 'paste' in the 'IMG code' and your picture will show up. You can use the 'preview' feature to make sure it worked correctly.
To Please help
