Project Creep: Stuck Lifter ?
Pulled the valve cover to find a bent pushrod.
Now do I assume its a bad lifter? DO I replace the lifter? All of the lifters? Cam and lifter? Do I just pony up and do heads now too?
If I throw a new lifter(s) in, what are the chances of damaging the cam?
Can I throw a set of aftermarket roller lifters and not swap the cam?
My quick pre-winter project is quickly growing.....
If the cam is wiped then u have major decision - to replace just cam or remove engine to complete disassemble and hot tank. This pretty much means a re-ring and re-bearing overhaul. Its all up to you. If your cam ate the lobes badly then u have a lot of metal in the oil pan and inside oil drains.
If just one lobe has damage then not so much metal is loose inside and possible still have long life with just a cam change. This is all up to your resources of time and money.
For example my "Hecho in Mexhico" crate 350 had one wiped lobe on the original cam with <35k mi. For a $1000 target motor i just put in another cam. Problem is that next cam wiped 3 lopes and when i checked the bearings i had a small gouge on 1 main bearing and one tiny gouge on 1 rod bearing. Yep, i replaced the bad bearings, hand polished the journals, and put in cam #3. Cam #3 is doing fine.
Just take one step at time and first find out status of cam. Let us know what u find so we can help give u better advice.
Hope i didn't scare u,
cardo0
Step one.
Replaced pushrod, turned motor over. Valve moves fine, full range of motion. (At least nothing obviously wrong at this point.)
Step Two
Compression test. The suspect cylinder #3 had the highest rating at 165. The others were all between 130-140. That tells me the rings and valves are sealing OK.
I would expect a bent intake valve to not seal.
Ill button her up and run it and see what happens.
If it occurs again, Ill order those AFR heads Ive been droolin over....
But as a cams lobes wear the compression increases - more mixture is trapped inside the cylinder. Less flow area as the intake goes shut while starting the compression stroke trapping more mixture.
And less overlap on that cylinder - this has more effect on idle quality than compression.Most expect compression to go down with cam wear but it really the opposite - compression increases.
U need to look at that lobe and lifter.
My sympathies,
cardo0
