Where to get proper idle adjustment screws
I popped the factory plugs off of my quadrajet to access the idle adjustment screws. I'd like to replace the factory adjustment screws with a slotted screws. Does anyone know where to get them? It appears that they don't come with rebuild kits.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,925 Likes
Why don't you just buy the right tool to use the stock screws?
I have 3 quadrajets, just switched to one with the slotted screw fittings. Behind the slotted screw is a 1/4" hex-shaft. I actually use a flexible tool I bought at kragen/O'Reilly that has a 1/4" hex-drive, much easier than using a screwdriver, especially since my car has A.I.R.. The passenger side idle adjustment is difficult to hit with the heater hose, AIR pump/lines, and the fuel line all in the immediate viscinity.
The later QJets (79+) either have a metrix hex or a DD head. The Thexton 350 tool works well for this.
You can buy the tool at any NAPA store for just a few bucks.
Lars
Lars
