quadrajet springs needed
Old Nov 22, 2012 | 07:55 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default quadrajet springs needed
Happy Thanksgiving everyone.
I noticed my rebuilt quadrajet was missing two springs from the choke area. Any way, I went on line and checked the assorted quadrajet parts guys google returned as matches.
No one lists these springs and I'm going to need them.
It is a restamped 70's Quadrajet stamped to a rarer 68 BB carb #.
It runs nice except for the tough cold starts.
I could never figure out the choke.
It is still the divorced choke on the manifold.
I replaced the bi-metalic coil and still no good.
I followed Lars set up which works if you have all the parts
I noticed while looking at choke parts on line, I was missing a spring off the cam/fast idle lever.
Also there is a spring of similar size and function that sits on the unloader shaft and connects to the choke pull off lever.
I do not know the proper name of this 2nd spring.
I realize now why the choke butterfly never set on cold start.
Any one know where these can be found?
Used works too.
I did find the GM# on the cam lever spring. 7035772.
Thanks Again,
Marshal
Old Nov 23, 2012 | 11:29 AM
lars's Avatar
lars
What's your carb number?
Also, is this just a re-stamped early '70s carb, or has the entire carb been "correctly" configured as a '68? The '68 float bowl is completely different from an early '70s carb, so stamping it won't "fix" the cosmetic configuration. Has all the choke linkage and all external parts been converted to the '68 style system..? Or is this carb still in its '70s configuration with a '68 carb number on it?
Lars
Old Nov 24, 2012 | 09:05 AM
marshal135's Avatar
marshal135
Lars,
Thanks for the response.
It is a 70's carb just stamped over as a 68(7028209 FG)
I think the internals are probably untouched still.
The choke linkage is a hodge podge of '71 replacement linkage
with a '68 style choke pull off. Hence it doesn't engage with the cam
lever.
I located the correct choke pull off based on looking at other
carbs w/ similar linkage and it looks to be a 1971 era.
The pics I have studied all show a fast idle cam lever wrapped w/ a spring.
Mine is not there
If you have one new or used I need it(please)
Thanks,
Marshal
Old Nov 24, 2012 | 10:20 AM
77C34SPD's Avatar
77C34SPD
This one? Name:  Picture 144.jpg
Old Nov 24, 2012 | 03:15 PM
marshal135's Avatar
marshal135
That's the 1
You got any extras?
Marshal
Old Nov 24, 2012 | 10:54 PM
lars's Avatar
lars
I can send you that spring, but it won't have any effect on the operation of your choke or on the solutions to the problems you have outlined in your original post - this spring does not pre-set the choke. The spring only provides a pre-load on the fast idle cam to prevent the fast idle cam from hanging up. That's not your problem, so you have other issues to identify and correct.
Lars
V8FastCars@msn.com
Old Nov 26, 2012 | 05:29 PM
marshal135's Avatar
marshal135
Lars,
I'd like to install the spring as it probably should be there.
It is the one in the pic in this post.
Can you let me know what I can do to purchase 1 please.
What I thought opened and closed the choke was the bi metalic coil so I replaced it.
I followed the set up procedure but it appears the coil doesn't have any effect on the choke .
The metal should expand upon heating correct?
It just sits full open.
It doesn't retract on cooling.
It does run nicely after initial warming.
I was hoping to get it 100%
Thanks,
Marshal
Old Nov 27, 2012 | 10:11 AM
lars's Avatar
lars
I'm waiting for you to e-mail me your address.
If your divorced choke coil is not reacting to heat changes, it's defective or installed wrong. When cold, the coil should pull the choke rod downwards, closing the choke. As it heats up, the coil should push the rod upwards, forcing the choke open. If the coil is installed backwards, it won't function correctly.
Lars
Old Nov 27, 2012 | 01:30 PM
fazang's Avatar
fazang
Marshal, Nice Car !
would love to see some pics of your Carb, to learn the differences of Qjets over the years.
As shown in pic in post 4 you can see the "saw teeth" on the cam to set the choke on cold start, what tooth did you set it to ?
Lar's post is dead on, as you turn the key on cold start you can watch the rod move and close the choke flap....does that even happen ?
Good Luck
-ALF out....
Old Nov 28, 2012 | 10:11 AM
lars's Avatar
lars
Your spring is in the mail. I also e-mailed you the figures out of the Service Manual showing the position and action of the choke coil related to the manifold and actuation rod.
If you can't get it running right, send me the carb: Your carb sounds like a real cluster of parts, and it's probable that it has a bunch of odd problems related to mismatched parts and missing/altered components.
Lars
Old Nov 28, 2012 | 10:51 AM
marshal135's Avatar
marshal135
Lars,
Thank you very much!
If I'm still having trouble with it, I would love to have you do your magic on it.
Everyone who sent their carb to you on this forum has raved about how it performs.
I was thinking about having you go through it and make it "right"
over the winter so I can enjoy it this spring '13.
Thank you again.
Fazang: I need to learn how to take pics
My wife took away my pic taking privileges at family get togethers cause I usually crop off feet or tops of heads.
We have a digital camera downstairs with a dead battery now.
I never was much a camera guy but I guess I going to have to learn if I'm going to keep asking for help.
Marshal
Old Dec 2, 2012 | 09:24 PM
marshal135's Avatar
marshal135
Lars,
Thank you very much for the fast idle cam lever spring.
I think after enough studying the choke parts and correcting
the hodge podge of parts, I have finally got the choke to close properly under choke coil tension
I'm now playing with bending an 1/8 " dia. length of rod to get the choke rod right.
To be continued.......
Marshal
To quadrajet springs needed
