speedometer off
Old Nov 24, 2012 | 08:56 PM
greghennings's Avatar
greghennings
Default speedometer off
When i bought my 76 vet, the previous owner told me that because he had installed 3.90 rear end gears that my speedometer would be off a bit. Its about 12 mph off, which i can actually live with. He told me that i'd need to change out a couple gears in the transmission to balance this problem. Where would i buy these gears and what would i be looking for?
I'm in the process of removing my motor from the car so i thought i'd ask about this, maybe its something i could fix while i'm at it. But maybe it's way more work than what its worth?
Last edited by greghennings; Nov 24, 2012 at 09:04 PM. Reason: had put down 3.80 instead of 3.90
Old Nov 24, 2012 | 10:16 PM
wombvette's Avatar
wombvette
Well. If he changed it to a 3:90 he really did something special. No such animal.
I am assuming its reading fast. All you have to do is slow it down by changing the speedo drive gear at the transmission. Probably about two teeth more than you currently have. Pull the gear and count teeth.
Old Nov 24, 2012 | 10:17 PM
7T1vette's Avatar
7T1vette
automatic or manual?
It would take a speedo drive gear (inside the rear of the trans (follow the speedo cable) with 3 more teeth....IF the gear on the tranny output shaft will allow that many teeth. Most parts places sell [or can get] speedo cable drive gears. But, you will need to know the exact gear ratio of the differential and your rear tire size.
Old Nov 25, 2012 | 09:31 AM
Street Rat's Avatar
Street Rat
This page has a wealth of information. The part numbers are GM. You may be able to get some of these through a local dealer. If not the Corvette vendors or transmission rebuilders usually have them.
http://chevelleengineer.home.comcast...eer/speedo.htm
Old Nov 25, 2012 | 10:22 AM
greghennings
hey thanks guys, i'm dealing with an automatic trans, i'll take a closer look here in the next couple days. Easy fix that i just thought of, I could keep my GPS in the car, its got a speedometer on it. I'm the only one that'll be driving it anyway...but it is nice when everything works properly.
To speedometer off
