battery light on
Old Nov 26, 2012 | 10:08 PM
Hamin79's Avatar
Hamin79
Default battery light on
I had a backfire through carb, replaced the cam problems went away. Now i have the battery light on all the time, while parked battery is at 12.13, while running battery is at 14.72, so battery and alternator are good to my knowledge what makes the battey light go out?
Old Nov 27, 2012 | 10:20 AM
MelWff's Avatar
MelWff
Isnt your alternator overcharging? Did you follow the diagnostic flow chart in the shop manual?
http://econofix.com/alt.html
http://www.delcoremy.com/Documents/d...ic-manual.aspx
Old Nov 27, 2012 | 10:53 PM
murfthsurf's Avatar
murfthsurf
If your car is a 79 start the car take a voltage tester go to ground and the brown wire comming out of the generator u should get 12 to 14 volts. It sounds like the generator is ok because it is charging. If you are getting voltage ck the fuse for you gages its 10 amp if it is blown replace fuse that will make the light go out.
To battery light on
