question about wheels. plz help.
Old Nov 28, 2012 | 09:27 PM
72blkstingray's Avatar
72blkstingray
Cruising
Default question about wheels. plz help.
i have a chance to buy some rims that are 18x8 with 4.5 backspacing all the way around. will this create any problems with clearance any where? Hope this set works i am getting a really good deal on these. Any help please. Thank you
Old Nov 28, 2012 | 09:32 PM
qwank's Avatar
qwank
I wouldn't buy them. Corvettes require 4" backspace on an 8" wheel
Old Nov 28, 2012 | 09:38 PM
72blkstingray
Cruising
the offset is 0 so from the corversion chart i found it would be 4.5 back spacing?
Old Nov 28, 2012 | 09:45 PM
RickyBerg's Avatar
RickyBerg
The stock 8x15" ralley wheels have 0 offset = 4" backspacing.
I run 9x16" with 0 offset = 4,5" backspacing and it works fine but i had to move the bracket for the parking brake wire from the outside to the top of the trailingarm.
//Ricky.
Old Nov 28, 2012 | 09:50 PM
Moser28's Avatar
Moser28
Stick with the 4" backspace. It works perfectly and you don't have to worry about clearance.
Old Nov 28, 2012 | 09:54 PM
72blkstingray
Cruising
Is there a " off the shelf" rim that any one knows of that has correct back spacing ? Want to put bigger rims and tires on. But don't want to spend a ton of money. I want 17 or 18's
Old Nov 28, 2012 | 10:51 PM
7t9l82's Avatar
7t9l82
what size wheels and tires ? looks good
Old Nov 28, 2012 | 11:29 PM
69autoXr's Avatar
69autoXr
//Ricky.
Not exactly. Wheel offset is calculated using the overall width of the wheel, which is usually about 1" wider than the advertised width. An 8" wheel is really about 9" wide overall from inner flange to outer flange(advertised widths are measured between the bead seats). 0 offset of an 8" wheel is 4.5" backspace, and stock rally wheels with 4" backspace are -12mm offset.
9" wheel with 0 offset = 5" backspace because the wheel is about 10" overall width. 9" wheel with 4.5" backspace is -12 mm offset.
This link has a handy table for converting backspace and offset:
https://rsracing.com/tech-wheel.html#backspace
Old Nov 28, 2012 | 11:44 PM
scottyp99's Avatar
scottyp99
They measure offset and backspacing this way because it makes soooooo much sense. If you just assume the wheel is an inch wider than advertized, it makes sense, which really doesn't make any sense. Does that make any sense?
Scott
Old Nov 30, 2012 | 07:47 AM
MN80Vette's Avatar
MN80Vette
I have 18x18 wheels with 4.5" backspacing and 255/45-18 tires on my '80. I had very minor rubbing at full lock.
One of our sons is a CNC machinist, so I had him make me a set of 3/8" spacers with an integrated hub centric adapter ring. (Original Corvette wheels are hub centric and after market wheels are lug centric. Adapters make after market wheels hub centric.)
No more rubbing, and the wheels come out to just about where the original wheels were in the wheel well. BTW, I chose 3/8" thick spacers instead of the full 1/2" difference so I wouldn't have to replace the original lugs with longers lugs.
Old Nov 30, 2012 | 08:40 AM
rafalc's Avatar
rafalc
Would your son consider making a few more and sell them here on the forum? I'm sure there may be buyers here....me included. I have 1/2" spacers on mine but they do not have the hub lip as yours do. I am also using shank lug nuts to accommodate for the extra distance.
Old Nov 30, 2012 | 09:44 AM
72blkstingray
Cruising
So I can run the 8.5 wheels with 4.5 back spacing if I use the adapters?
Old Nov 30, 2012 | 10:15 AM
RickyBerg's Avatar
RickyBerg
I see.
I measure my wheels from the inner surface of the center and to the inboard flange and to the outboard flange. If these measures are the same the wheel has a 0 offset.
One offcourse also need to consider the tyre bulking out outside the rim with a posability of rubbing the trailingarm.
Old Dec 7, 2012 | 08:07 AM
Dheista's Avatar
Dheista
Default Need spacers too
Agreed - would be interested in that as well.
Old Dec 7, 2012 | 04:13 PM
glackore's Avatar
glackore
72blkstingray: measure twice and then measure once more. Don't take anything for granted as these cars can be slightly different car-2-car. Also consider the tire sidewall sticking out past the wheel lip. The measurements for most tires can be found on the manufacturer web site(s). This is all simple math - just take your time and measure properly. Here is a link to a web site showing how to measure BS:
http://www.vintagewheelworks.com/tech-backspace.php
Gary
Old Dec 8, 2012 | 09:42 AM
MN80Vette's Avatar
MN80Vette
Yes, he will make more. He can make 1/2" spacers too if you have longer lugs than stock or you are willing to take a chance with stock lugs and less than the lug diameter in threads inside the nut.
Old Dec 8, 2012 | 09:54 AM
MN80Vette's Avatar
MN80Vette
Gary
We have dimensions to fit BOSS 338 and TT2 wheels now. He can make adapters-only (if you don't need a spacer but want hub centric) or spacer-adapters for other brands if you have the specs.
A CF member who bought the first set for TT2 had a little difficulty getting them on the front hubs and had to dress the front hugs. C3 front and rear hubs have slightly different diameters.
Anyone measuring a different wheel needs to remember that machinists work 3 places to the right of the decimal point. Cast hubs are not very precise. The fit of these adapters or spacer-adapters are at least as precise as stock wheels on the hubs.
To question about wheels. plz help.
Old Dec 8, 2012 | 10:03 AM
3JsVette's Avatar
3JsVette
These are a work of art! Your son's work is something to be proud of.
Old Dec 9, 2012 | 02:40 PM
MN80Vette's Avatar
MN80Vette
And he makes us Christmas ornaments too!
Old Dec 9, 2012 | 09:11 PM
3JsVette's Avatar
3JsVette
