Head lights blowing
Old Nov 29, 2012 | 07:53 AM
ewhensley's Avatar
ewhensley
Default Head lights blowing
Hello, I have a 73 that blows head light bulbs at hign rpm. When you speed up they get bright and blow. I was thinking alternator, would appreciate any input. Earl
Old Nov 29, 2012 | 09:11 AM
SIXFOOTER's Avatar
SIXFOOTER
Yep, regulator in the alternator has issues
Old Nov 29, 2012 | 09:19 AM
Indiancreek's Avatar
Indiancreek
Just had a Jag in here doing the samething. At idle it was putting out 15.25 volts. I didn't bother to see what was being put out at rpm. The Jag has an enternal regulator that went bad.
Old Dec 5, 2012 | 09:08 PM
ewhensley's Avatar
ewhensley
Today I replaced the alternator, head lights are still blowing while driving at a higher rpm, when in park they will not blow, I haven't had time to do a lot of research. Thanks for any input.
Old Dec 5, 2012 | 09:25 PM
7.3 dave's Avatar
7.3 dave
may have the external voltage regulator? not sure
Old Dec 5, 2012 | 09:36 PM
TimAT's Avatar
TimAT
AS sixfooter noted- regulator has issues. And in 73, the regulator is internal to the alternator. Pull it and get it checked.
Old Dec 15, 2012 | 10:28 AM
ewhensley's Avatar
ewhensley
Yes, I was thinking alternator, but checked out good. Just dont have a lot of time now. Thanks
Old Jan 17, 2013 | 08:03 AM
ewhensley's Avatar
ewhensley
Problem solved, loose connection at starter. I have no idea why I was getting high voltage only at the head lights. Thanks for all the input. Earl
To Head lights blowing
