69 L88
Old Jun 8, 2002 | 11:18 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default 69 L88
what did they REALLY make for hp ? I'm thinking about breaking the bank and building one up
Old Jun 8, 2002 | 11:24 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
Default Re: 69 L88 (Corzvette69)
:eek: are you serious? I've heard lots of different HP numbers, just depends how you tune it I guess. I'm thinking about mid 400s
:cheers:
Old Jun 9, 2002 | 12:50 AM
SuperFast80's Avatar
SuperFast80
Automobile Mag Nov '88:
Corvette Fever Jan '93
Car and Driver June '89
Old Jun 9, 2002 | 02:05 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: 69 L88 (SuperFast80)
Unless you HAVE to have an L-88 you don't want one, they are not very streetable at all, won't idle at low rpms, need premium gas, don't make as much power as a decent crate motor of today. They are neat to think about regarding corvette heritage, or to have one sit in your garge for an occasional drive, but for a car you want to drive a lot, they would be a pain in the butt. But to each his own. :chevy
Old Jun 9, 2002 | 02:15 AM
theanswriz42
:eek: i was really off!
Old Jun 9, 2002 | 09:44 AM
bud snyder's Avatar
bud snyder
Default Re: 69 L88 (69 N.O.X. RATT)
69 N.O.X. Is absolutely correct. I have a Guy in town that has an original 69 LeMans Blue L89.
It gets 6 MPG on Rase gas at $4.75 per gallon and he has to drive 30 miles each way to get it or store it in a drum at home. The Car sets a lot!
The engine sounds nasty with the factory side pipes, but not the best choice for a Corvette.
He sold a Pristine 65 & 66 to get this car and says it was the biggest mistake he ever made.
He can't afford to drive it and is afraid to really get on it for fear of destroying something.
Bud
Old Jun 9, 2002 | 11:54 AM
fontking1a's Avatar
fontking1a
Default Re: 69 L88 (theanswriz42)
:cheers:
Maybe more like 500....?
Old Jun 9, 2002 | 12:18 PM
Corey_68's Avatar
Corey_68
Default Re: 69 L88 (fontking1a)
Do a search in O.T. ans in the Kill section, there was heated debate in the past. You'll find 5+ pages of debate in each section. :yesnod:
Old Jun 9, 2002 | 12:52 PM
Corz's Avatar
Corz
Default Re: 69 L88 (Corey 68)
damn! i want one.... or would i be better off S/C my 327 ?
Old Jun 9, 2002 | 02:30 PM
Corey_68's Avatar
Corey_68
There NOTHING like a B.B. :yesnod:
Old Jun 9, 2002 | 10:08 PM
Dave68's Avatar
Dave68
I agree 100%. If you want massive power output, get an HO502 crate engine that'll pump out 450-502 HP without even trying.
However, if you want a more balanced setup and don't want to change-out all your accessories, get the ZZ4. 400 lbs-ft of torque at under 4000 rpms is not too shabby either!
Old Jun 9, 2002 | 11:06 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The L88's biggest obsticle to street use was it's 12.5:1 compression ratio. Even 100 octane pump gas was marginal. The single largest contributor to it's power increase over an L72 was the cam. In the late `60's, the cam could be had for $28 ( lifters were 50 cents each!) and they were a popular over the counter item. The L88's 430hp power rating was accurate, they just chose to publish it's output over 1,000 rpm below it peak power. Most of the dyno figures I've seen for L88's have put their peak power in the 550 hp range at from 6,600 - 6,800 rpm with headers and low restriction exhaust.
Old Jun 10, 2002 | 12:13 AM
java0881's Avatar
java0881
my engine is very close to L88 specs and i agree with all you said.but nothing gives you a wider grin than flooring a high revving solid lifter big block :D
Old Jun 10, 2002 | 12:33 AM
Corz's Avatar
Corz
Default Re: 69 L88 (java0881)
now thats what i want, something close to the L88, but streetable. solid lifters, nice cam, ported/polished heads 10:1 compression and all that good stuff.. now if i only had a 3rd pedal I would have my dream corvette
Old Jun 10, 2002 | 03:43 AM
Chuck Harmon's Avatar
Chuck Harmon
Java,
Mine is to factory specs and I agree with you! The biggest help to its drivability is the ROD 6 speed and 3.08 gears. Now that I have re-timed the cam to straight up specs instead of 4 degrees advanced, I find the cam to be much more drivable. I am no longer in a hurry to change it.
No doubt a more modern grind would give me even better numbers, as would a new intake manifold design; but, the current power level is nothing less than impressive. The grins are very hard to suppress! I am still somewhat self conscious about the noise in a populated environment, but power steering and light clutch pedal effort from a dual disc McLeod setup would make the task of driving around town a very easy and pleasurable matter. I still wouldn't want to try to talk anyone into getting a L88 vs. another engine for their car. I will simply state that I am very happy with my decision. A well chosen roller cam would make it just about perfect. Someday ...
Chuck
Chuck
Old Jun 10, 2002 | 02:09 PM
Chuck Harmon
Corey,
When I replied to your post I didn't take the time to see what you are starting with. I started with a 69 350/350 very similar to your setup, but with a 4 speed. I had to change everything. Radiator, rear end, transmission, suspension, exhaust, etc. to make the change. An automatic will have to be reworked, even the great Turbo 400 like you probably have, but automatics are still about the worst choice for any long cammed engine.
I really believe you would be a lot happier, especially if this is your only car, to change cam, intake, exhaust, and carb and build closer to 400 gross horse power. The Richmond 5 speed is easier and cheaper to install than the 6 speed and will allow you to hold your own even against a real L88 with 3.36 gears and 4 speed through 1st gear. A modified 4 speed automatic will also come very close. A new tranny can make for a great secret weapon and equalizer!
You really need long, windy open roads to truly enjoy the L88. If you spend much time in a city, a stout small block or mild big block is a better choice.
Chuck
Old Jun 10, 2002 | 03:24 PM
69 N.O.X. RATT
I agree, I have a .030 over solid roller cammed 454 that sees 6400 rpms (Rev limiter) several times a week. When all that exhaust is flowing through three inch pipes and out of flowmaster 40's it makes me grin for a long time. :chevy
Old Jun 10, 2002 | 05:04 PM
Robert N's Avatar
Robert N
There is always the option of building a solid 350 modeled after the LT-1.
Old Jun 10, 2002 | 05:20 PM
Chuck Harmon
Default Re: 69 L88 (wireless guy)
Quote:
________________________________________ ____________________
My second favorite engine! This is what I had in mind when I referred to a small block close to 400 gross horse power, which is closer to what the LT1 actually made.
Chuck
Chuck
To 69 L88
